Geometry Class Referenceabstract
#include <gz/rendering/Geometry.hh>
 Clone the geometry.
 Get the parent Visual.
◆ ~Geometry()
virtual ~Geometry ( )
◆ Clone()
◆ HasParent()
Implemented in OgreGeometry, and Ogre2Geometry.
◆ Parent()
◆ RemoveParent()
virtual void RemoveParent ( )
Implemented in BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
◆ SetMaterial() [1/2]
bool  _unique = true
Implemented in BaseGeometry< T >, BaseGeometry< Ogre2Object >, BaseGeometry< OgreObject >, BaseMesh< T >, BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in OgreCapsule, OgreGrid, OgreHeightmap, OgreMarker, OgreText, OgreWireBox, Ogre2Capsule, Ogre2Grid, Ogre2Heightmap, Ogre2Marker, Ogre2WireBox, BaseMesh< T >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
