Ogre2 implementation of a grid geometry. More...
#include <Ogre2Grid.hh>
 ~Ogre2Grid () override
void Init () override
MaterialPtr Material () const override
Ogre::MovableObject * OgreObject () const override
 Get the ogre object representing this geometry.
void PreRender () override
void SetMaterial (MaterialPtr _material, bool _unique) override
 Set the materials of this Geometry.
- Public Member Functions inherited from BaseGrid< Ogre2Geometry >
 ~BaseGrid () override
unsigned int CellCount () const override
 Get the number of cells on a planar grid.
double CellLength () const override
 Get the cell length.
void Destroy () override
void SetCellCount (const unsigned int _count) override
 Set the number of cells on a planar grid.
void SetCellLength (const double _len) override
 Set the cell length in one direction. The cells are assumed to be square.
void SetVerticalCellCount (const unsigned int _count) override
 Set the vertical cell count of the grid. This makes the grid 3D.
unsigned int VerticalCellCount () const override
 Get the vertical cell count.
virtual ~Grid ()
virtual ~Ogre2Geometry ()
 Get the parent Visual.
 ~BaseGeometry () override
 Clone the geometry.
void RemoveParent () override
 Ogre2Grid ()
 Set material to grid geometry.
- Protected Member Functions inherited from BaseGrid< Ogre2Geometry >
 BaseGrid ()
 Ogre2Geometry ()
 Set the parent of this ogre geometry.
 BaseGeometry ()
- Protected Attributes inherited from BaseGrid< Ogre2Geometry >
unsigned int cellCount
 Number of cells in grid.
double cellLength
 Length of a single cell.
bool gridDirty
 Flag to indicate grid properties have changed.
double heightOffset
 vertical offset of the XY plane from origin
unsigned int verticalCellCount
 Number of cells in vertical direction.
Ogre2VisualPtr parent
 Parent visual.
 Pointer to the ogre scene.
◆ Ogre2Grid()
Ogre2Grid ( )
◆ ~Ogre2Grid()
~Ogre2Grid ( )
void Init ( )
Implements Geometry.
◆ OgreObject()
Ogre::MovableObject * OgreObject ( ) const
Implements Ogre2Geometry.
void PreRender ( )
Reimplemented from BaseGrid< Ogre2Geometry >.
◆ SetMaterial()
bool  _unique
◆ SetMaterialImpl()
[in]_materialOgre material.
