BaseGeometry< T > Class Template Referenceabstract
#include <BaseGeometry.hh>
 ~BaseGeometry () override
 Clone the geometry.
void Destroy () override
VisualPtr Parent () const override=0
 Get the parent Visual.
void RemoveParent () override
void SetMaterial (MaterialPtr _material, bool _unique=true) override=0
 BaseGeometry ()
◆ BaseGeometry()
template<class T >
BaseGeometry ( )
◆ ~BaseGeometry()
template<class T >
~BaseGeometry ( )
◆ Clone()
template<class T >
GeometryPtr Clone ( ) const
Clone the geometry.
The cloned geometry.
Implements Geometry.
Reimplemented in BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
References gzwarn.
template<class T >
void Destroy ( )
◆ Parent()
template<class T >
VisualPtr Parent ( ) const
overridepure virtual
the parent Visual
Implemented in OgreGeometry, and Ogre2Geometry.
◆ RemoveParent()
template<class T >
void RemoveParent ( )
References std::dynamic_pointer_cast().
◆ SetMaterial() [1/2]
template<class T >
bool  _unique = true
References Scene::Material().
◆ SetMaterial() [2/2]
template<class T >
bool  _unique = true
Implemented in OgreCapsule, OgreGrid, OgreHeightmap, OgreMarker, OgreText, OgreWireBox, Ogre2Capsule, Ogre2Grid, Ogre2Heightmap, Ogre2Marker, Ogre2WireBox, BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
