#include <OgreMesh.hh>
virtual ~OgreMesh ()
 Check whether the mesh has skeleton.
 Set whether a skeleton animation should be enabled or not.
 Set transforms for the skeleton.
 Set skeleton node weight.
 Get whether a skeleton animation is enabled or not.
 Get the skeleton local transforms.
 Get skeleton node weight.
 Play the active skeleton animation to the specified time.
- Public Member Functions inherited from BaseMesh< OgreGeometry >
virtual ~BaseMesh ()
 Clone the geometry.
 Get the mesh's mesh descriptor.
 Determine if has given sub-mesh.
 Determine if has sub-mesh with given name.
 Set the mesh's descriptor.
 Get sub-mesh at given index.
 Get sub-mesh with given name.
 Get the sub-mesh count.
virtual ~Mesh ()
 ~OgreGeometry () override
 Get the parent Visual.
 ~BaseGeometry () override
void RemoveParent () override
 OgreMesh ()
virtual SubMeshStorePtr SubMeshes () const override
- Protected Member Functions inherited from BaseMesh< OgreGeometry >
 BaseMesh ()
 OgreGeometry ()
 BaseGeometry ()
virtual void Init ()
Ogre::Entity * ogreEntity = nullptr
OgreSubMeshStorePtr subMeshes
- Protected Attributes inherited from BaseMesh< OgreGeometry >
 Pointer to currently assigned material.
MeshDescriptor meshDescriptor
 MeshDescriptor for this mesh.
bool ownsMaterial
 Flag to indicate whether or not this mesh should be responsible for destroying the material.
OgreVisualPtr parent
◆ OgreMesh()
OgreMesh ( )
◆ ~OgreMesh()
virtual ~OgreMesh ( )
Reimplemented from BaseMesh< OgreGeometry >.
◆ HasSkeleton()
True if the mesh has skeleton
◆ OgreObject()
Implements OgreGeometry.
bool  _enabled,
bool  _loop = true,
float  _weight = 1.0
[in]_nameName of animation
  • Map holding:
    • Skeleton node names
◆ SetSkeletonWeights()
  • Map holding:
    • Weight the skeleton nodes
◆ SkeletonAnimationEnabled()
◆ SkeletonLocalTransforms()
virtual std::map< std::string, math::Matrix4d > SkeletonLocalTransforms ( ) const
  • Map holding:
◆ SkeletonWeights()
virtual std::unordered_map< std::string, float > SkeletonWeights ( ) const
  • Map holding:
◆ SubMeshes()
◆ UpdateSkeletonAnimation()
◆ ogreEntity
Ogre::Entity* ogreEntity = nullptr
◆ subMeshes
