Mesh Class Referenceabstract
Represents a collection of mesh geometries. More...
#include <gz/rendering/Mesh>
virtual ~Mesh ()
virtual const MeshDescriptor & Descriptor () const =0
 Get the mesh's mesh descriptor.
virtual bool HasSkeleton () const =0
 Check whether the mesh has skeleton.
virtual bool HasSubMesh (ConstSubMeshPtr _subMesh) const =0
 Determine if has given sub-mesh.
virtual bool HasSubMeshName (const std::string &_name) const =0
 Determine if has sub-mesh with given name.
virtual void SetDescriptor (const MeshDescriptor &_desc)=0
 Set the mesh's descriptor.
virtual void SetSkeletonAnimationEnabled (const std::string &_name, bool _enabled, bool _loop=true, float _weight=1.0)=0
 Set whether a skeleton animation should be enabled or not.
virtual void SetSkeletonLocalTransforms (const std::map< std::string, math::Matrix4d > &_tfs)=0
 Set transforms for the skeleton.
virtual void SetSkeletonWeights (const std::unordered_map< std::string, float > &_weights)=0
 Set skeleton node weight.
virtual bool SkeletonAnimationEnabled (const std::string &_name) const =0
 Get whether a skeleton animation is enabled or not.
virtual std::map< std::string, math::Matrix4d > SkeletonLocalTransforms () const =0
 Get the skeleton local transforms.
virtual std::unordered_map< std::string, float > SkeletonWeights () const =0
 Get skeleton node weight.
virtual SubMeshPtr SubMeshByIndex (unsigned int _index) const =0
 Get sub-mesh at given index.
virtual SubMeshPtr SubMeshByName (const std::string &_name) const =0
 Get sub-mesh with given name.
virtual unsigned int SubMeshCount () const =0
 Get the sub-mesh count.
virtual void UpdateSkeletonAnimation (std::chrono::steady_clock::duration _time)=0
 Play the active skeleton animation to the specified time.
 Clone the geometry.
 Get the parent Visual.
◆ ~Mesh()
virtual ~Mesh ( )
◆ Descriptor()
virtual const MeshDescriptor & Descriptor ( ) const
The mesh's mesh descriptor
Implemented in BaseMesh< T >, BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
◆ HasSkeleton()
True if the mesh has skeleton
Implemented in BaseMesh< T >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, OgreMesh, and Ogre2Mesh.
◆ HasSubMesh()
virtual bool HasSubMesh ( ConstSubMeshPtr  _subMesh) const
[in]_subMeshSub-mesh in question
True if has given sub-mesh
◆ HasSubMeshName()
virtual bool HasSubMeshName ( const std::string &  _name) const
[in]_nameName of sub-mesh in question
True if has sub-mesh with given name
◆ SetDescriptor()
virtual void SetDescriptor ( const MeshDescriptor &  _desc)
[in]_descThe new mesh descriptor
bool  _enabled,
bool  _loop = true,
float  _weight = 1.0
[in]_nameName of animation
  • Map holding:
    • Skeleton node names
◆ SetSkeletonWeights()
  • Map holding:
    • Weight the skeleton nodes
◆ SkeletonAnimationEnabled()
◆ SkeletonLocalTransforms()
virtual std::map< std::string, math::Matrix4d > SkeletonLocalTransforms ( ) const
  • Map holding:
◆ SkeletonWeights()
virtual std::unordered_map< std::string, float > SkeletonWeights ( ) const
  • Map holding:
◆ SubMeshByIndex()
virtual SubMeshPtr SubMeshByIndex ( unsigned int  _index) const
[in]_indexIndex of sub-mesh
The sub-mesh at the given index
◆ SubMeshByName()
virtual SubMeshPtr SubMeshByName ( const std::string &  _name) const
The sub-mesh with the given name
◆ SubMeshCount()
virtual unsigned int SubMeshCount ( ) const
The sub-mesh count
◆ UpdateSkeletonAnimation()
