Ogre2.x implementation of the mesh class. More...
#include <Ogre2Mesh.hh>
virtual ~Ogre2Mesh ()
 Check whether the mesh has skeleton.
 Get the ogre object representing this geometry.
 Set whether a skeleton animation should be enabled or not.
 Set transforms for the skeleton.
 Set skeleton node weight.
 Get whether a skeleton animation is enabled or not.
 Get the skeleton local transforms.
 Get skeleton node weight.
 Play the active skeleton animation to the specified time.
- Public Member Functions inherited from BaseMesh< Ogre2Geometry >
virtual ~BaseMesh ()
 Clone the geometry.
 Get the mesh's mesh descriptor.
 Determine if has given sub-mesh.
 Determine if has sub-mesh with given name.
 Set the mesh's descriptor.
 Get sub-mesh at given index.
 Get sub-mesh with given name.
 Get the sub-mesh count.
virtual ~Mesh ()
virtual ~Ogre2Geometry ()
 Get the parent Visual.
 ~BaseGeometry () override
void RemoveParent () override
 Ogre2Mesh ()
virtual SubMeshStorePtr SubMeshes () const override
 Get a list of submeshes in this mesh.
- Protected Member Functions inherited from BaseMesh< Ogre2Geometry >
 BaseMesh ()
 Ogre2Geometry ()
 Set the parent of this ogre geometry.
 BaseGeometry ()
virtual void Init ()
Ogre::Item * ogreItem = nullptr
 Pointer to the ogre item object.
Ogre2SubMeshStorePtr subMeshes
 Store containing all the submeshes.
- Protected Attributes inherited from BaseMesh< Ogre2Geometry >
 Pointer to currently assigned material.
MeshDescriptor meshDescriptor
 MeshDescriptor for this mesh.
bool ownsMaterial
 Flag to indicate whether or not this mesh should be responsible for destroying the material.
Ogre2VisualPtr parent
 Parent visual.
 Pointer to the ogre scene.
◆ Ogre2Mesh()
Ogre2Mesh ( )
◆ ~Ogre2Mesh()
virtual ~Ogre2Mesh ( )
Reimplemented from BaseMesh< Ogre2Geometry >.
◆ HasSkeleton()
True if the mesh has skeleton
◆ OgreObject()
Implements Ogre2Geometry.
bool  _enabled,
bool  _loop = true,
float  _weight = 1.0
[in]_nameName of animation
  • Map holding:
    • Skeleton node names
◆ SetSkeletonWeights()
  • Map holding:
    • Weight the skeleton nodes
◆ SkeletonAnimationEnabled()
◆ SkeletonLocalTransforms()
virtual std::map< std::string, math::Matrix4d > SkeletonLocalTransforms ( ) const
  • Map holding:
◆ SkeletonWeights()
virtual std::unordered_map< std::string, float > SkeletonWeights ( ) const
  • Map holding:
◆ SubMeshes()
Implements BaseMesh< Ogre2Geometry >.
◆ UpdateSkeletonAnimation()
◆ ogreItem
Ogre::Item* ogreItem = nullptr
◆ subMeshes
