Base implementation of a text geometry. More...
#include <BaseText.hh>
 ~BaseText () override
gz::math::AxisAlignedBox AABB () const override
 Get the axis aligned bounding box of the text.
float Baseline () const override
 Get the baseline height in meters.
float CharHeight () const override
 Get the height of the characters in meters return Height of the characters.
gz::math::Color Color () const override
 Get the text color.
void Destroy () override
std::string FontName () const override
 Get the font name.
TextHorizontalAlign HorizontalAlignment () const override
 Get the horizontal alignment of the text.
void PreRender () override
void SetBaseline (const float _baseline) override
 Set the baseline height of the text.
void SetCharHeight (const float _height) override
 Set the height of the character in meters.
void SetColor (const gz::math::Color &_color) override
 Set the text color.
void SetFontName (const std::string &_font) override
 Set the font.
void SetShowOnTop (const bool _onTop) override
 True = text always is displayed on top.
void SetSpaceWidth (const float _width) override
 Set the width of spaces between words.
void SetTextAlignment (const TextHorizontalAlign &_hAlign, const TextVerticalAlign &_vAlign) override
 Set the alignment of the text.
void SetTextString (const std::string &_text) override
 Set the text to display.
bool ShowOnTop () const override
 Get whether the is displayed above other objects.
float SpaceWidth () const override
 Get the width of spaces between words.
std::string TextString () const override
 Get the displayed text.
TextVerticalAlign VerticalAlignment () const override
 Get the vertical alignment of the text.
- Public Member Functions inherited from Text
 Text ()=default
virtual ~Text ()
 Clone the geometry.
 Get the parent Visual.
 BaseText ()
float baseline = 0
 Baseline height in meters.
float charHeight = 1.0
 Character height in meters.
gz::math::Color color = gz::math::Color::White
 Text color.
std::string fontName = "Liberation Sans"
 Font name, such as "Liberation Sans".
TextHorizontalAlign horizontalAlign
 Horizontal alignment.
bool onTop = false
 True for text to be displayed on top of other objects in the scene.
float spaceWidth = 0
 Width of space between letters.
std::string text
 Text being displayed.
bool textDirty = false
 Flag to indicate text properties have changed.
TextVerticalAlign verticalAlign = TextVerticalAlign::BOTTOM
 Vertical alignment.
template<class T>
class gz::rendering::BaseText< T >
◆ BaseText()
template<class T >
BaseText ( )
◆ ~BaseText()
template<class T >
~BaseText ( )
◆ AABB()
template<class T >
gz::math::AxisAlignedBox AABB ( ) const
Implements Text.
Reimplemented in OgreText.
◆ Baseline()
template<class T >
float Baseline ( ) const
Baseline height
SetBaseline()
Implements Text.
◆ CharHeight()
template<class T >
float CharHeight ( ) const
SetCharHeight()
Implements Text.
◆ Color()
template<class T >
gz::math::Color Color ( ) const
Get the text color.
Text color.
SetColor()
Implements Text.
template<class T >
void Destroy ( )
◆ FontName()
template<class T >
std::string FontName ( ) const
Get the font name.
The font name.
SetFontName()
Implements Text.
◆ HorizontalAlignment()
template<class T >
TextHorizontalAlign HorizontalAlignment ( ) const
Text horizontal alignment
Implements Text.
template<class T >
void PreRender ( )
◆ SetBaseline()
template<class T >
void SetBaseline ( const float  _baseline)
[in]_baselineBaseline height
Baseline()
Implements Text.
◆ SetCharHeight()
template<class T >
void SetCharHeight ( const float  _height)
CharHeight()
Implements Text.
◆ SetColor()
template<class T >
void SetColor ( const gz::math::Color &  _color)
Set the text color.
[in]_colorText color.
Color()
Implements Text.
◆ SetFontName()
template<class T >
void SetFontName ( const std::string &  _font)
Set the font.
[in]_fontName of the font
FontName()
Implements Text.
◆ SetShowOnTop()
template<class T >
void SetShowOnTop ( const bool  _onTop)
ShowOnTop()
Implements Text.
◆ SetSpaceWidth()
template<class T >
void SetSpaceWidth ( const float  _width)
[in]_widthSpace width
SpaceWidth()
Implements Text.
◆ SetTextAlignment()
template<class T >
void SetTextAlignment ( const TextHorizontalAlign &  _hAlign,
[in]_vAlignVertical alignment
Implements Text.
◆ SetTextString()
template<class T >
void SetTextString ( const std::string &  _text)
[in]_textThe text to display.
Text()
Implements Text.
◆ ShowOnTop()
template<class T >
bool ShowOnTop ( ) const
True if it is on top.
SetShowOnTop()
Implements Text.
◆ SpaceWidth()
template<class T >
float SpaceWidth ( ) const
Space width
SetSpaceWidth()
Implements Text.
◆ TextString()
template<class T >
std::string TextString ( ) const
The displayed text.
SetText()
Implements Text.
◆ VerticalAlignment()
template<class T >
TextVerticalAlign VerticalAlignment ( ) const
Text vertical alignment
Implements Text.
◆ baseline
template<class T >
float baseline = 0
◆ charHeight
template<class T >
◆ color
template<class T >
Text color.
◆ fontName
template<class T >
◆ horizontalAlign
template<class T >
Initial value:
◆ onTop
template<class T >
bool onTop = false
◆ spaceWidth
template<class T >
◆ text
template<class T >
std::string text
◆ textDirty
template<class T >
◆ verticalAlign
template<class T >
Vertical alignment.
