Ogre implementation of text geometry. More...
#include <OgreText.hh>
virtual ~OgreText ()
virtual gz::math::AxisAlignedBox AABB () const override
 Get the axis aligned bounding box of the text.
virtual void SetBaseline (const float _baseline) override
 Set the baseline height of the text.
virtual void SetCharHeight (const float _height) override
 Set the height of the character in meters.
virtual void SetColor (const gz::math::Color &_color) override
 Set the text color.
virtual void SetFontName (const std::string &_font) override
 Set the font.
 Set the materials of this Geometry.
virtual void SetShowOnTop (const bool _onTop) override
 True = text always is displayed on top.
virtual void SetSpaceWidth (const float _width) override
 Set the width of spaces between words.
virtual void SetTextAlignment (const TextHorizontalAlign &_horizAlign, const TextVerticalAlign &_vertAlign) override
 Set the alignment of the text.
virtual void SetTextString (const std::string &_text) override
 Set the text to display.
- Public Member Functions inherited from BaseText< OgreGeometry >
 ~BaseText () override
float Baseline () const override
 Get the baseline height in meters.
float CharHeight () const override
 Get the height of the characters in meters return Height of the characters.
gz::math::Color Color () const override
 Get the text color.
void Destroy () override
std::string FontName () const override
 Get the font name.
TextHorizontalAlign HorizontalAlignment () const override
 Get the horizontal alignment of the text.
bool ShowOnTop () const override
 Get whether the is displayed above other objects.
float SpaceWidth () const override
 Get the width of spaces between words.
std::string TextString () const override
 Get the displayed text.
TextVerticalAlign VerticalAlignment () const override
 Get the vertical alignment of the text.
- Public Member Functions inherited from Text
 Text ()=default
virtual ~Text ()
 ~OgreGeometry () override
 Get the parent Visual.
 ~BaseGeometry () override
 Clone the geometry.
void RemoveParent () override
 OgreText ()
 Set material to text geometry.
- Protected Member Functions inherited from BaseText< OgreGeometry >
 BaseText ()
 OgreGeometry ()
 BaseGeometry ()
- Protected Attributes inherited from BaseText< OgreGeometry >
float baseline
 Baseline height in meters.
float charHeight
 Character height in meters.
gz::math::Color color
 Text color.
std::string fontName
 Font name, such as "Liberation Sans".
TextHorizontalAlign horizontalAlign
 Horizontal alignment.
bool onTop
 True for text to be displayed on top of other objects in the scene.
float spaceWidth
 Width of space between letters.
std::string text
 Text being displayed.
bool textDirty
 Flag to indicate text properties have changed.
TextVerticalAlign verticalAlign
 Vertical alignment.
OgreVisualPtr parent
◆ OgreText()
OgreText ( )
◆ ~OgreText()
virtual ~OgreText ( )
◆ AABB()
virtual gz::math::AxisAlignedBox AABB ( ) const
Reimplemented from BaseText< OgreGeometry >.
Implements Geometry.
◆ OgreObject()
Implements OgreGeometry.
◆ SetBaseline()
[in]_baselineBaseline height
Baseline()
◆ SetCharHeight()
CharHeight()
◆ SetColor()
virtual void SetColor ( const gz::math::Color &  _color)
Set the text color.
[in]_colorText color.
Color()
◆ SetFontName()
Set the font.
[in]_fontName of the font
FontName()
◆ SetMaterial()
bool  _unique
◆ SetMaterialImpl()
[in]_materialOgre material.
◆ SetShowOnTop()
ShowOnTop()
◆ SetSpaceWidth()
[in]_widthSpace width
SpaceWidth()
◆ SetTextAlignment()
[in]_vAlignVertical alignment
◆ SetTextString()
[in]_textThe text to display.
Text()
