Ogre implementation of a heightmap geometry. More...
#include <OgreHeightmap.hh>
virtual ~OgreHeightmap ()
 Returns NULL, heightmap materials don't inherit from MaterialPtr.
 Returns NULL, heightmaps don't have movable objects.
 Has no effect for heightmaps. The material is set through a HeightmapDescriptor.
- Public Member Functions inherited from BaseHeightmap< OgreGeometry >
virtual const HeightmapDescriptor & Descriptor () override
 Get the immutable heightmap descriptor.
 ~OgreGeometry () override
 Get the parent Visual.
 ~BaseGeometry () override
 Clone the geometry.
void RemoveParent () override
 OgreHeightmap (const HeightmapDescriptor &_desc)
- Protected Member Functions inherited from BaseHeightmap< OgreGeometry >
 BaseHeightmap (const HeightmapDescriptor &_desc)
 OgreGeometry ()
 BaseGeometry ()
- Public Attributes inherited from BaseHeightmap< OgreGeometry >
HeightmapDescriptor descriptor
 Descriptor containing heightmap information.
OgreVisualPtr parent
◆ OgreHeightmap()
OgreHeightmap ( const HeightmapDescriptor &  _desc)
explicitprotected
◆ ~OgreHeightmap()
virtual ~OgreHeightmap ( )
Null pointer.
Implements Geometry.
◆ OgreObject()
Null pointer.
Implements OgreGeometry.
Reimplemented from BaseHeightmap< OgreGeometry >.
◆ SetMaterial()
bool  _unique
[in]_materialNot used.
[in]_uniqueNot used.
