#include <BaseHeightmap.hh>
virtual const HeightmapDescriptor & Descriptor () override
 Get the immutable heightmap descriptor.
 Clone the geometry.
 Get the parent Visual.
Public Attributes
HeightmapDescriptor descriptor
 Descriptor containing heightmap information.
 BaseHeightmap (const HeightmapDescriptor &_desc)
◆ BaseHeightmap()
template<class T >
BaseHeightmap ( const HeightmapDescriptor &  _desc)
explicitprotected
[in]_descDescriptor containing heightmap information.
◆ Descriptor()
template<class T >
const HeightmapDescriptor & Descriptor ( )
Descriptor with heightmap information.
Implements Heightmap.
template<class T >
void Destroy ( )
Reimplemented in Ogre2Heightmap.
template<class T >
void PreRender ( )
Reimplemented in OgreHeightmap, and Ogre2Heightmap.
◆ descriptor
template<class T >
