Heightmap Class Referenceabstract
A terrain defined by a heightfield. More...
#include <gz/rendering/Heightmap>
virtual const HeightmapDescriptor & Descriptor ()=0
 Get the immutable heightmap descriptor.
 Clone the geometry.
 Get the parent Visual.
◆ Descriptor()
virtual const HeightmapDescriptor & Descriptor ( )
Descriptor with heightmap information.
Implemented in BaseHeightmap< T >, BaseHeightmap< Ogre2Geometry >, and BaseHeightmap< OgreGeometry >.
