Ogre2Heightmap Class Reference
Ogre implementation of a heightmap geometry. More...
#include <Ogre2Heightmap.hh>
 Ogre2Heightmap (const HeightmapDescriptor &_desc)
virtual ~Ogre2Heightmap () override
 Returns NULL, heightmap materials don't inherit from MaterialPtr.
 Returns the Terra pointer as it is a movable object that must be attached to a regular SceneNode.
 Has no effect for heightmaps. The material is set through a HeightmapDescriptor.
Ogre::Terra * Terra ()
void UpdateForRender (Ogre::Camera *_activeCamera)
- Public Member Functions inherited from BaseHeightmap< Ogre2Geometry >
virtual const HeightmapDescriptor & Descriptor () override
 Get the immutable heightmap descriptor.
virtual ~Ogre2Geometry ()
 Get the parent Visual.
 ~BaseGeometry () override
 Clone the geometry.
void RemoveParent () override
- Public Attributes inherited from BaseHeightmap< Ogre2Geometry >
HeightmapDescriptor descriptor
 Descriptor containing heightmap information.
- Protected Member Functions inherited from BaseHeightmap< Ogre2Geometry >
 BaseHeightmap (const HeightmapDescriptor &_desc)
 Ogre2Geometry ()
 Set the parent of this ogre geometry.
 BaseGeometry ()
Ogre2VisualPtr parent
 Parent visual.
 Pointer to the ogre scene.
◆ Ogre2Heightmap()
Ogre2Heightmap ( const HeightmapDescriptor &  _desc)
[in]_descParameters describing how a heightmap should be loaded
◆ ~Ogre2Heightmap()
virtual ~Ogre2Heightmap ( )
Reimplemented from BaseHeightmap< Ogre2Geometry >.
Null pointer.
Implements Geometry.
◆ OgreObject()
Remarks
This behavior is different from ogre1
Terra pointer
Implements Ogre2Geometry.
◆ SetMaterial()
bool  _unique
[in]_materialNot used.
[in]_uniqueNot used.
◆ Terra()
Ogre::Terra * Terra ( )
◆ UpdateForRender()
void UpdateForRender ( Ogre::Camera *  _activeCamera)
