#include <Ogre2Marker.hh>
virtual ~Ogre2Marker ()
 Add a point with its respective color to the marker.
 Clear the points of the marker, if applicable.
 Destroy function.
 Get the ogre object representing this geometry.
 PreRender function.
 Set the materials of this Geometry.
 Set an existing point's vector.
 Set the render type of this Marker.
 Get the render type of this Marker.
- Public Member Functions inherited from BaseMarker< Ogre2Geometry >
virtual ~BaseMarker ()
 Get the layer of this Marker.
 Get the lifetime of this Marker.
 Set the layer of this Marker.
 Set the lifetime of this Marker.
 Set size of the marker. Only affects MT_POINTS. e.g. size of rasterized points in pixels.
 Get the size of the marker.
virtual ~Marker ()
virtual ~Ogre2Geometry ()
 Get the parent Visual.
 ~BaseGeometry () override
 Clone the geometry.
void RemoveParent () override
 Ogre2Marker ()
- Protected Member Functions inherited from BaseMarker< Ogre2Geometry >
 BaseMarker ()
 Marker ()
 Ogre2Geometry ()
 Set the parent of this ogre geometry.
 BaseGeometry ()
- Protected Attributes inherited from BaseMarker< Ogre2Geometry >
int32_t layer
 Layer at which the marker will reside.
 Life time of a marker.
bool markerDirty
 Flag to indicate if marker needs to be updated.
MarkerType markerType
 Marker type.
double size
 Marker size.
Ogre2VisualPtr parent
 Parent visual.
 Pointer to the ogre scene.
◆ Ogre2Marker()
Ogre2Marker ( )
◆ ~Ogre2Marker()
virtual ~Ogre2Marker ( )
◆ AddPoint()
Reimplemented from BaseMarker< Ogre2Geometry >.
◆ ClearPoints()
virtual void ClearPoints ( )
Destroy function.
Implements Geometry.
◆ OgreObject()
Implements Ogre2Geometry.
PreRender function.
◆ SetMaterial()
bool  _unique
◆ SetPoint()
◆ SetType()
◆ Type()
The render type of the marker
