#include <BaseMarker.hh>
virtual ~BaseMarker ()
 Add a point with its respective color to the marker.
 Clear the points of the marker, if applicable.
 Destroy function.
 Get the layer of this Marker.
 Get the lifetime of this Marker.
 PreRender function.
 Set the layer of this Marker.
 Set the lifetime of this Marker.
 Set an existing point's vector.
 Set size of the marker. Only affects MT_POINTS. e.g. size of rasterized points in pixels.
 Set the render type of this Marker.
 Get the size of the marker.
 Get the render type of this Marker.
virtual ~Marker ()
 Clone the geometry.
 Get the parent Visual.
 BaseMarker ()
 Marker ()
int32_t layer = 0
 Layer at which the marker will reside.
 Life time of a marker.
bool markerDirty = false
 Flag to indicate if marker needs to be updated.
MarkerType markerType
 Marker type.
double size = 1.0
 Marker size.
template<class T>
class gz::rendering::BaseMarker< T >
◆ BaseMarker()
template<class T >
BaseMarker ( )
◆ ~BaseMarker()
template<class T >
~BaseMarker ( )
◆ AddPoint() [1/2]
template<class T >
void AddPoint ( const gz::math::Vector3d &  _pt,
Implements Marker.
Reimplemented in OgreMarker, and Ogre2Marker.
◆ AddPoint() [2/2]
template<class T >
void AddPoint ( double  _x,
double  _y,
double  _z,
[in]_xX coordinate
[in]_yY coordinate
[in]_zZ coordinate
Implements Marker.
◆ ClearPoints()
template<class T >
void ClearPoints ( )
Implements Marker.
template<class T >
void Destroy ( )
Destroy function.
◆ Layer()
template<class T >
int32_t Layer ( ) const
The layer of the marker
Implements Marker.
◆ Lifetime()
template<class T >
std::chrono::steady_clock::duration Lifetime ( ) const
Implements Marker.
template<class T >
void PreRender ( )
PreRender function.
◆ SetLayer()
template<class T >
void SetLayer ( int32_t  _layer)
Implements Marker.
◆ SetLifetime()
template<class T >
void SetLifetime ( const std::chrono::steady_clock::duration &  _lifetime)
Implements Marker.
◆ SetPoint()
template<class T >
Implements Marker.
◆ SetSize()
template<class T >
void SetSize ( double  _size)
[in]_sizeSize of the marker
Implements Marker.
◆ SetType()
template<class T >
void SetType ( const MarkerType  _markerType)
Implements Marker.
◆ Size()
template<class T >
double Size ( ) const
The size of the marker
SetSize
Implements Marker.
◆ Type()
template<class T >
MarkerType Type ( ) const
The render type of the marker
Implements Marker.
◆ layer
template<class T >
int32_t layer = 0
◆ lifetime
template<class T >
Initial value:
std::chrono::steady_clock::duration::zero()
◆ markerDirty
template<class T >
◆ markerType
template<class T >
Initial value:
Marker type.
◆ size
template<class T >
double size = 1.0
Marker size.
