Base implementation of a wireframe box. More...
#include <BaseWireBox.hh>
 ~BaseWireBox () override
gz::math::AxisAlignedBox Box () const override
 Get the wireframe box.
void Destroy () override
void PreRender () override
void SetBox (const gz::math::AxisAlignedBox &_box) override
 Set the axis aligned box.
- Public Member Functions inherited from WireBox
virtual ~WireBox ()
 Clone the geometry.
 Get the parent Visual.
 BaseWireBox ()
- Protected Member Functions inherited from WireBox
 WireBox ()
gz::math::AxisAlignedBox box
bool wireBoxDirty = false
 Flag to indicate WireBox properties have changed.
template<class T>
class gz::rendering::BaseWireBox< T >
◆ BaseWireBox()
template<class T >
BaseWireBox ( )
◆ ~BaseWireBox()
template<class T >
~BaseWireBox ( )
◆ Box()
template<class T >
gz::math::AxisAlignedBox Box ( ) const
The wireframe box.
Implements WireBox.
template<class T >
void Destroy ( )
template<class T >
void PreRender ( )
Reimplemented in OgreWireBox, and Ogre2WireBox.
◆ SetBox()
template<class T >
void SetBox ( const gz::math::AxisAlignedBox &  _box)
[in]_boxThe axis aligned box
Implements WireBox.
◆ box
template<class T >
◆ wireBoxDirty
template<class T >
