Ogre implementation of a wire box geometry. More...
#include <OgreWireBox.hh>
virtual ~OgreWireBox ()
 Set the materials of this Geometry.
- Public Member Functions inherited from BaseWireBox< OgreGeometry >
 ~BaseWireBox () override
gz::math::AxisAlignedBox Box () const override
 Get the wireframe box.
void Destroy () override
void SetBox (const gz::math::AxisAlignedBox &_box) override
 Set the axis aligned box.
- Public Member Functions inherited from WireBox
virtual ~WireBox ()
 ~OgreGeometry () override
 Get the parent Visual.
 ~BaseGeometry () override
 Clone the geometry.
void RemoveParent () override
 OgreWireBox ()
 Set material to wire box geometry.
- Protected Member Functions inherited from BaseWireBox< OgreGeometry >
 BaseWireBox ()
- Protected Member Functions inherited from WireBox
 WireBox ()
 OgreGeometry ()
 BaseGeometry ()
- Protected Attributes inherited from BaseWireBox< OgreGeometry >
gz::math::AxisAlignedBox box
bool wireBoxDirty
 Flag to indicate WireBox properties have changed.
OgreVisualPtr parent
◆ OgreWireBox()
OgreWireBox ( )
◆ ~OgreWireBox()
virtual ~OgreWireBox ( )
Implements Geometry.
◆ OgreObject()
Implements OgreGeometry.
Reimplemented from BaseWireBox< OgreGeometry >.
◆ SetMaterial()
bool  _unique
◆ SetMaterialImpl()
[in]_materialOgre material.
