Base implementation of an center of mass visual. More...
#include <BaseCOMVisual.hh>
virtual ~BaseCOMVisual ()
virtual gz::math::Pose3d InertiaPose () const override
 Get the inertia pose.
virtual double Mass () const override
 Get the mass of the parent.
 Set the inertial component of the visual.
virtual void SetMass (double _mass) override
 Set the mass of the parent.
virtual VisualPtr SphereVisual () const override
 Get the sphere visual.
- Public Member Functions inherited from COMVisual
virtual ~COMVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseCOMVisual ()
double SphereRadius () const
 Get the radius of the CoM sphere.
bool dirtyCOMVisual = false
 Flag to indicate parent properties have changed.
gz::math::Pose3d inertiaPose
 Inertia pose in parent frame.
double mass = 1.0
 Parent mass.
std::string parentName = ""
 Parent visual name.
template<class T>
class gz::rendering::BaseCOMVisual< T >
◆ BaseCOMVisual()
template<class T >
BaseCOMVisual ( )
◆ ~BaseCOMVisual()
template<class T >
~BaseCOMVisual ( )
◆ InertiaPose()
template<class T >
gz::math::Pose3d InertiaPose ( ) const
Implements COMVisual.
template<class T >
void Init ( )
Reimplemented in OgreCOMVisual, and Ogre2COMVisual.
◆ Mass()
template<class T >
double Mass ( ) const
Parent mass
template<class T >
void PreRender ( )
◆ SetInertial()
template<class T >
void SetInertial ( const gz::math::Inertiald &  _inertial)
References Inertial< typename T >::MassMatrix(), and Inertial< typename T >::Pose().
◆ SetMass()
template<class T >
void SetMass ( double  _mass)
[in]_massParent mass
References gzlog.
◆ SphereRadius()
template<class T >
double SphereRadius ( ) const
Radius of the CoM sphere
References GZ_PI.
◆ SphereVisual()
template<class T >
VisualPtr SphereVisual ( ) const
Pointer to the sphere visual
◆ dirtyCOMVisual
template<class T >
◆ inertiaPose
template<class T >
Initial value:
◆ mass
template<class T >
double mass = 1.0
Parent mass.
◆ parentName
template<class T >
Parent visual name.
