#include <OgreCOMVisual.hh>
virtual ~OgreCOMVisual ()
void CreateVisual ()
 Create the Light Visual in Ogre.
 Set the material for all attached visuals and geometries.
virtual VisualPtr SphereVisual () const override
 Get the sphere visual.
- Public Member Functions inherited from BaseCOMVisual< OgreVisual >
virtual ~BaseCOMVisual ()
virtual gz::math::Pose3d InertiaPose () const override
 Get the inertia pose.
virtual double Mass () const override
 Get the mass of the parent.
 Set the inertial component of the visual.
virtual void SetMass (double _mass) override
 Set the mass of the parent.
- Public Member Functions inherited from COMVisual
virtual ~COMVisual ()
virtual ~OgreVisual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreCOMVisual ()
 Set material to grid geometry.
- Protected Member Functions inherited from BaseCOMVisual< OgreVisual >
 BaseCOMVisual ()
double SphereRadius () const
 Get the radius of the CoM sphere.
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseCOMVisual< OgreVisual >
bool dirtyCOMVisual
 Flag to indicate parent properties have changed.
gz::math::Pose3d inertiaPose
 Inertia pose in parent frame.
double mass
 Parent mass.
std::string parentName
 Parent visual name.
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreCOMVisual()
OgreCOMVisual ( )
◆ ~OgreCOMVisual()
virtual ~OgreCOMVisual ( )
◆ CreateVisual()
void CreateVisual ( )
Reimplemented from BaseCOMVisual< OgreVisual >.
Implements Visual.
◆ OgreObject()
Ogre::MovableObject * OgreObject ( ) const
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
◆ SphereVisual()
Pointer to the sphere visual
