Light Class Referenceabstract
Represents a light source in the scene graph. More...
#include <gz/rendering/Light.hh>
virtual ~Light ()
 Get the attenuation range.
 Get the diffuse color.
 Get the light intensity.
 Set the attenuation range.
 Set the diffuse color.
 Set the light intensity.
 Set the specular color.
 Get the specular color.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~Light()
virtual ~Light ( )
◆ AttenuationConstant()
Implemented in OgreLight, and Ogre2Light.
◆ AttenuationLinear()
The attenuation linear value
◆ AttenuationQuadratic()
◆ AttenuationRange()
The attenuation range
◆ CastShadows()
◆ DiffuseColor()
The diffuse color
◆ Intensity()
virtual double Intensity ( ) const
The light intensity
◆ SetAttenuationConstant()
Implemented in OgreLight, Ogre2Light, BaseLight< T >, BaseLight< Ogre2Node >, and BaseLight< OgreNode >.
◆ SetAttenuationLinear()
◆ SetAttenuationQuadratic()
◆ SetAttenuationRange()
◆ SetCastShadows()
◆ SetDiffuseColor() [1/2]
[in]_colorNew diffuse color
◆ SetDiffuseColor() [2/2]
virtual void SetDiffuseColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Implemented in BaseLight< T >, BaseLight< Ogre2Node >, and BaseLight< OgreNode >.
◆ SetIntensity()
virtual void SetIntensity ( double  _intensity)
[in]_intensityNew light intensity
◆ SetSpecularColor() [1/2]
[in]_colorNew specular color
◆ SetSpecularColor() [2/2]
virtual void SetSpecularColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SpecularColor()
The specular color
