BaseLight< T > Class Template Referenceabstract
#include <BaseLight.hh>
 ~BaseLight () override
void SetAttenuationConstant (double _value) override=0
void SetAttenuationLinear (double _value) override=0
void SetAttenuationQuadratic (double _value) override=0
void SetAttenuationRange (double _range) override=0
 Set the attenuation range.
void SetCastShadows (bool _castShadows) override=0
void SetDiffuseColor (const math::Color &_color) override=0
 Set the diffuse color.
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (const math::Color &_color) override=0
 Set the specular color.
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~Light ()
 Get the attenuation range.
 Get the diffuse color.
 Get the light intensity.
 Set the light intensity.
 Get the specular color.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseLight ()
◆ BaseLight()
template<class T >
BaseLight ( )
◆ ~BaseLight()
template<class T >
~BaseLight ( )
◆ Reset()
template<class T >
void Reset ( )
◆ SetAttenuationConstant()
template<class T >
void SetAttenuationConstant ( double  _value)
overridepure virtual
Implements Light.
Implemented in OgreLight, and Ogre2Light.
◆ SetAttenuationLinear()
template<class T >
void SetAttenuationLinear ( double  _value)
Implements Light.
◆ SetAttenuationQuadratic()
template<class T >
void SetAttenuationQuadratic ( double  _value)
Implements Light.
◆ SetAttenuationRange()
template<class T >
void SetAttenuationRange ( double  _range)
Implements Light.
◆ SetCastShadows()
template<class T >
void SetCastShadows ( bool  _castShadows)
Implements Light.
◆ SetDiffuseColor() [1/2]
template<class T >
void SetDiffuseColor ( const math::Color &  _color)
[in]_colorNew diffuse color
Implements Light.
◆ SetDiffuseColor() [2/2]
template<class T >
void SetDiffuseColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Implements Light.
◆ SetSpecularColor() [1/2]
template<class T >
void SetSpecularColor ( const math::Color &  _color)
[in]_colorNew specular color
Implements Light.
◆ SetSpecularColor() [2/2]
template<class T >
void SetSpecularColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Implements Light.
