BaseSpotLight< T > Class Template Referenceabstract
#include <BaseLight.hh>
 ~BaseSpotLight () override
void SetDirection (const math::Vector3d &_dir) override=0
void SetDirection (double _x, double _y, double _z) override
void SetFalloff (double _falloff) override=0
 Set the falloff of the spotlight.
void SetInnerAngle (const math::Angle &_angle) override=0
 Set the inner angle of the spotlight.
void SetInnerAngle (double _radians) override
void SetOuterAngle (const math::Angle &_angle) override=0
 Set the outer angle of the spotlight.
void SetOuterAngle (double _radians) override
virtual ~SpotLight ()
 Get direction of the light.
 Get the falloff of the spotlight.
 Get the inner angle of the spotlight.
 Get the outer angle of the spotlight.
virtual ~Light ()
 Get the attenuation range.
 Get the diffuse color.
 Get the light intensity.
 Set the attenuation range.
 Set the diffuse color.
 Set the light intensity.
 Set the specular color.
 Get the specular color.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseSpotLight ()
void Reset () override
◆ BaseSpotLight()
template<class T >
BaseSpotLight ( )
◆ ~BaseSpotLight()
template<class T >
~BaseSpotLight ( )
◆ Reset()
template<class T >
void Reset ( )
overrideprotected
References GZ_PI.
◆ SetDirection() [1/2]
template<class T >
overridepure virtual
[in]_dirNew direction vector
Implements SpotLight.
Implemented in OgreSpotLight, and Ogre2SpotLight.
◆ SetDirection() [2/2]
template<class T >
void SetDirection ( double  _x,
double  _y,
double  _z
◆ SetFalloff()
template<class T >
void SetFalloff ( double  _falloff)
◆ SetInnerAngle() [1/2]
template<class T >
void SetInnerAngle ( const math::Angle &  _angle)
◆ SetInnerAngle() [2/2]
template<class T >
void SetInnerAngle ( double  _radians)
◆ SetOuterAngle() [1/2]
template<class T >
void SetOuterAngle ( const math::Angle &  _angle)
◆ SetOuterAngle() [2/2]
template<class T >
void SetOuterAngle ( double  _radians)
