SpotLight Class Referenceabstract
#include <gz/rendering/Light.hh>
virtual ~SpotLight ()
 Get direction of the light.
 Get the falloff of the spotlight.
 Get the inner angle of the spotlight.
 Get the outer angle of the spotlight.
 Set the falloff of the spotlight.
 Set the inner angle of the spotlight.
virtual void SetInnerAngle (double _radians)=0
 Set the outer angle of the spotlight.
virtual void SetOuterAngle (double _radians)=0
virtual ~Light ()
 Get the attenuation range.
 Get the diffuse color.
 Get the light intensity.
 Set the attenuation range.
 Set the diffuse color.
 Set the light intensity.
 Set the specular color.
 Get the specular color.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~SpotLight()
virtual ~SpotLight ( )
◆ Direction()
The direction of the light
Implemented in OgreSpotLight, and Ogre2SpotLight.
◆ Falloff()
The falloff of the spotlight
◆ InnerAngle()
◆ OuterAngle()
◆ SetDirection() [1/2]
[in]_dirNew direction vector
Implemented in OgreSpotLight, Ogre2SpotLight, BaseSpotLight< T >, BaseSpotLight< Ogre2Light >, and BaseSpotLight< OgreLight >.
◆ SetDirection() [2/2]
double  _y,
double  _z
Implemented in BaseSpotLight< T >, BaseSpotLight< Ogre2Light >, and BaseSpotLight< OgreLight >.
◆ SetFalloff()
◆ SetInnerAngle() [1/2]
◆ SetInnerAngle() [2/2]
virtual void SetInnerAngle ( double  _radians)
◆ SetOuterAngle() [1/2]
◆ SetOuterAngle() [2/2]
virtual void SetOuterAngle ( double  _radians)
