Ogre 2.x implementation of the spot light class. More...
#include <Ogre2Light.hh>
virtual ~Ogre2SpotLight ()
 Get direction of the light.
virtual double Falloff () const override
 Get the falloff of the spotlight.
virtual math::Angle InnerAngle () const override
 Get the inner angle of the spotlight.
virtual math::Angle OuterAngle () const override
 Get the outer angle of the spotlight.
virtual void SetFalloff (double _falloff) override
 Set the falloff of the spotlight.
virtual void SetInnerAngle (const math::Angle &_angle) override
 Set the inner angle of the spotlight.
virtual void SetOuterAngle (const math::Angle &_angle) override
 Set the outer angle of the spotlight.
- Public Member Functions inherited from BaseSpotLight< Ogre2Light >
 ~BaseSpotLight () override
void SetDirection (double _x, double _y, double _z) override
void SetInnerAngle (double _radians) override
void SetOuterAngle (double _radians) override
virtual ~SpotLight ()
virtual ~Light ()
virtual ~Ogre2Light ()
 Get the attenuation range.
 Destroy the light.
 Get the diffuse color.
 Get the light intensity.
 Get a pointer to ogre light.
 Set the attenuation range.
 Set the diffuse color.
 Set the light intensity.
 Set the local position.
 Set the specular color.
 Get the specular color.
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 Ogre2SpotLight ()
- Protected Member Functions inherited from BaseSpotLight< Ogre2Light >
 BaseSpotLight ()
void Reset () override
 Ogre2Light ()
 Initialize the light.
 BaseLight ()
 Ogre2Node ()
 Set the parent node.
double attenConstant = 1.0
 Attenuation constant value.
double attenLinear = 0.0
 Attenuation linear factor.
double attenQuadratic = 0.0
 Attenuation quadratic factor.
double attenRange = 100.0
 Attenuation range.
 Pointer to ogre light.
 Light type.
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2SpotLight()
Ogre2SpotLight ( )
◆ ~Ogre2SpotLight()
virtual ~Ogre2SpotLight ( )
◆ Direction()
The direction of the light
Implements SpotLight.
◆ Falloff()
The falloff of the spotlight
◆ InnerAngle()
◆ OuterAngle()
◆ SetDirection()
[in]_dirNew direction vector
Implements BaseSpotLight< Ogre2Light >.
◆ SetFalloff()
◆ SetInnerAngle()
◆ SetOuterAngle()
