#include <OgreLight.hh>
 ~OgreLight () override
 Get the attenuation range.
 Get the diffuse color.
 Get the light intensity.
void SetAttenuationConstant (double _value) override
void SetAttenuationLinear (double _value) override
void SetAttenuationQuadratic (double _value) override
void SetAttenuationRange (double _range) override
 Set the attenuation range.
void SetCastShadows (bool _castShadows) override
void SetDiffuseColor (const math::Color &_color) override
 Set the diffuse color.
 Set the light intensity.
void SetSpecularColor (const math::Color &_color) override
 Set the specular color.
 Get the specular color.
 ~BaseLight () override
void SetDiffuseColor (double _r, double _g, double _b, double _a=1.0) override
void SetSpecularColor (double _r, double _g, double _b, double _a=1.0) override
virtual ~Light ()
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreLight ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreLight()
OgreLight ( )
◆ ~OgreLight()
~OgreLight ( )
◆ AttenuationConstant()
Implements Light.
◆ AttenuationLinear()
The attenuation linear value
Implements Light.
◆ AttenuationQuadratic()
Implements Light.
◆ AttenuationRange()
The attenuation range
Implements Light.
◆ CastShadows()
Implements Light.
◆ DiffuseColor()
The diffuse color
Implements Light.
Reimplemented from OgreNode.
◆ Intensity()
virtual double Intensity ( ) const
The light intensity
Implements Light.
◆ Light()
virtual Ogre::Light * Light ( ) const
◆ SetAttenuationConstant()
void SetAttenuationConstant ( double  _value)
Implements BaseLight< OgreNode >.
◆ SetAttenuationLinear()
void SetAttenuationLinear ( double  _value)
◆ SetAttenuationQuadratic()
void SetAttenuationQuadratic ( double  _value)
◆ SetAttenuationRange()
void SetAttenuationRange ( double  _range)
◆ SetCastShadows()
void SetCastShadows ( bool  _castShadows)
◆ SetDiffuseColor()
void SetDiffuseColor ( const math::Color &  _color)
[in]_colorNew diffuse color
◆ SetIntensity()
virtual void SetIntensity ( double  _intensity)
[in]_intensityNew light intensity
Implements Light.
◆ SetSpecularColor()
void SetSpecularColor ( const math::Color &  _color)
[in]_colorNew specular color
◆ SpecularColor()
The specular color
Implements Light.
◆ attenConstant
◆ attenLinear
double attenLinear
◆ attenQuadratic
◆ attenRange
double attenRange
◆ ogreLight
Ogre::Light* ogreLight
◆ ogreLightType
