#include <OgreNode.hh>
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreNode ()
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreNode()
OgreNode ( )
◆ ~OgreNode()
virtual ~OgreNode ( )
◆ AttachChild()
◆ Children()
virtual NodeStorePtr Children ( ) const
Reimplemented from BaseNode< OgreObject >.
Reimplemented in BaseArrowVisual< OgreVisual >, BaseAxisVisual< OgreVisual >, BaseFrustumVisual< OgreVisual >, BaseJointVisual< OgreVisual >, BaseLidarVisual< OgreVisual >, BaseVisual< OgreNode >, OgreCamera, OgreDepthCamera, OgreFrustumVisual, OgreGpuRays, OgreLidarVisual, OgreLight, OgreThermalCamera, and OgreWideAngleCamera.
◆ DetachChild()
virtual bool DetachChild ( NodePtr  _child)
◆ HasParent()
Implements Node.
◆ InheritScale()
Implements BaseNode< OgreObject >.
◆ Load()
virtual void Load ( )
Reimplemented in BaseCamera< OgreSensor >.
◆ LocalScale()
The local scale
Reimplemented in BaseAxisVisual< OgreVisual >.
◆ Node()
virtual Ogre::SceneNode * Node ( ) const
◆ Parent()
the parent Node
◆ RawLocalPose()
◆ RawLocalPosition()
virtual math::Vector3d RawLocalPosition ( ) const
◆ RawLocalRotation()
virtual math::Quaterniond RawLocalRotation ( ) const
◆ SetInheritScale()
[in]_inheritTrue if this node inherits scale from its parent
Implements Node.
◆ SetLocalScaleImpl()
◆ SetParent()
virtual void SetParent ( OgreNodePtr  _parent)
◆ SetRawLocalPose()
virtual void SetRawLocalPose ( const math::Pose3d &  _Pose3d)
◆ SetRawLocalPosition()
virtual void SetRawLocalPosition ( const math::Vector3d &  _position)
◆ SetRawLocalRotation()
virtual void SetRawLocalRotation ( const math::Quaterniond &  _rotation)
◆ children
◆ ogreNode
Ogre::SceneNode* ogreNode = nullptr
◆ parent
OgreNodePtr parent
