#include <BaseArrowVisual.hh>
virtual ~BaseArrowVisual ()
 Get arrow-head visual.
 Get arrow-rotation visual.
 Get arrow-shaft visual.
 set true to show the arrow head, false otherwise
 Set true to show the rotation of the arrow, false otherwise.
 set true to show the arrow shaft, false otherwise
virtual ~ArrowVisual ()
virtual ~CompositeVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseArrowVisual ()
bool rotationVisible = false
 Flag to indicate whether arrow rotation is visible.
◆ BaseArrowVisual()
template<class T >
BaseArrowVisual ( )
◆ ~BaseArrowVisual()
template<class T >
~BaseArrowVisual ( )
template<class T >
void Destroy ( )
References std::dynamic_pointer_cast().
◆ Head()
template<class T >
VisualPtr Head ( ) const
The arrow-head visual
Implements ArrowVisual.
template<class T >
void Init ( )
◆ Rotation()
template<class T >
VisualPtr Rotation ( ) const
The arrow-rotation visual
◆ SetVisible()
template<class T >
Implements Visual.
◆ Shaft()
template<class T >
VisualPtr Shaft ( ) const
The arrow-shaft visual
◆ ShowArrowHead()
template<class T >
void ShowArrowHead ( bool  _b)
[in]_btrue to show the arrow head, false otherwise
◆ ShowArrowRotation()
template<class T >
void ShowArrowRotation ( bool  _b)
[in]_bTrue to show the arrow rotation.
◆ ShowArrowShaft()
template<class T >
void ShowArrowShaft ( bool  _b)
[in]_btrue to show the arrow shaft, false otherwise
◆ rotationVisible
template<class T >
