ArrowVisual Class Referenceabstract
Represents a arrow composite visual. More...
#include <gz/rendering/ArrowVisual.hh>
virtual ~ArrowVisual ()
virtual VisualPtr Head () const =0
 Get arrow-head visual.
virtual VisualPtr Rotation () const =0
 Get arrow-rotation visual.
virtual VisualPtr Shaft () const =0
 Get arrow-shaft visual.
virtual void ShowArrowHead (bool _b)=0
 set true to show the arrow head, false otherwise
virtual void ShowArrowRotation (bool _b)=0
 Set true to show the rotation of the arrow, false otherwise.
virtual void ShowArrowShaft (bool _b)=0
 set true to show the arrow shaft, false otherwise
virtual ~CompositeVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~ArrowVisual()
virtual ~ArrowVisual ( )
◆ Head()
virtual VisualPtr Head ( ) const
The arrow-head visual
Implemented in BaseArrowVisual< T >, BaseArrowVisual< Ogre2Visual >, and BaseArrowVisual< OgreVisual >.
◆ Rotation()
virtual VisualPtr Rotation ( ) const
The arrow-rotation visual
◆ Shaft()
virtual VisualPtr Shaft ( ) const
The arrow-shaft visual
◆ ShowArrowHead()
virtual void ShowArrowHead ( bool  _b)
[in]_btrue to show the arrow head, false otherwise
◆ ShowArrowRotation()
virtual void ShowArrowRotation ( bool  _b)
[in]_bTrue to show the arrow rotation.
◆ ShowArrowShaft()
virtual void ShowArrowShaft ( bool  _b)
[in]_btrue to show the arrow shaft, false otherwise
