Base implementation of a Lidar Visual. More...
#include <BaseLidarVisual.hh>
virtual ~BaseLidarVisual ()
 Clear the points of the lidar visual.
 Create predefined materials for lidar visual.
 Get if non-hitting rays will be displayed.
 Get number of horizontal rays.
 Get maximum horizontal angle.
 Get maximum range of lidar rays.
 Get minimum vertical angle.
 Get minimum horizontal angle.
 Get minimum range of lidar rays.
virtual gz::math::Pose3d Offset () const override
 Get offset of visual.
 Get number of points in laser data.
 Get the points in laser data.
 Set if non-hitting rays will be displayed (this does not work for TRIANGLE_STRIPS visual)
 Set number of horizontal rays.
 Set maximum horizontal angle.
 Set maximum range of lidar rays.
 Set maximum vertical angle.
 Set minimum horizontal angle.
 Set minimum range of lidar rays.
 Set minimum vertical angle.
virtual void SetOffset (const gz::math::Pose3d _offset) override
 Set offset of visual.
 Set lidar points to be visualised.
virtual void SetPoints (const std::vector< double > &_points, const std::vector< gz::math::Color > &_colors) override
 Set size of the lidar visualization, e.g. size of rasterized lidar points in pixels.
 Set type for lidar visual.
 Set number of vertical rays.
 Get size of the lidar visualization.
 Get the type for lidar visual.
 Update the Visual.
 Get number of vertical rays.
virtual ~LidarVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseLidarVisual ()
 LidarVisual ()
bool displayNonHitting = true
 Option to display non-hitting rays.
double horizontalAngleStep = 0
 Angle between two horizontal rays.
unsigned int horizontalCount = 1u
 Horizontal laser count.
 Type of lidar visualisation.
double maxHorizontalAngle = 0
 Horizontal maximum angle.
double maxRange = 0
 Maximum Range.
double maxVerticalAngle = 0
 Vertical maximum angle.
double minHorizontalAngle = 0
 Horizontal minimal angle.
double minRange = 0
 Minimum Range.
double minVerticalAngle = 0
 Vertical minimal angle.
gz::math::Pose3d offset = gz::math::Pose3d::Zero
 Offset of visual.
double size = 1.0
 Size of lidar visualisation.
double verticalAngleStep = 0
 Angle between two vertical rays.
unsigned int verticalCount = 1u
 Vertical laser count.
template<class T>
class gz::rendering::BaseLidarVisual< T >
◆ BaseLidarVisual()
template<class T >
BaseLidarVisual ( )
◆ ~BaseLidarVisual()
template<class T >
~BaseLidarVisual ( )
◆ ClearPoints()
template<class T >
void ClearPoints ( )
Implements LidarVisual.
Reimplemented in OgreLidarVisual, and Ogre2LidarVisual.
◆ CreateMaterials()
template<class T >
void CreateMaterials ( )
References Scene::CreateMaterial().
template<class T >
void Destroy ( )
◆ DisplayNonHitting()
template<class T >
bool DisplayNonHitting ( ) const
Boolean value if non-hitting rays will be displayed
◆ HorizontalRayCount()
template<class T >
unsigned int HorizontalRayCount ( ) const
The number of horizontal rays
template<class T >
void Init ( )
◆ MaxHorizontalAngle()
template<class T >
double MaxHorizontalAngle ( ) const
The maximum horizontal angle value of the lidar visual
◆ MaxRange()
template<class T >
double MaxRange ( ) const
The maximum range for lidar rays
◆ MaxVerticalAngle()
template<class T >
double MaxVerticalAngle ( ) const
The maximum vertical angle value of the lidar visual
◆ MinHorizontalAngle()
template<class T >
double MinHorizontalAngle ( ) const
The minimum horizontal angle value of the lidar visual
◆ MinRange()
template<class T >
double MinRange ( ) const
The minimum range for lidar rays
◆ MinVerticalAngle()
template<class T >
double MinVerticalAngle ( ) const
The minimum vertical angle value of the lidar visual
◆ Offset()
template<class T >
gz::math::Pose3d Offset ( ) const
The offset of the lidar rays from visual origin
◆ PointCount()
template<class T >
◆ Points()
template<class T >
std::vector< double > Points ( ) const
The points in the laser data
template<class T >
void PreRender ( )
◆ SetDisplayNonHitting()
template<class T >
void SetDisplayNonHitting ( bool  _display)
[in]_displayBoolean value to display non hitting visuals
◆ SetHorizontalRayCount()
template<class T >
void SetHorizontalRayCount ( unsigned int  _horizontalRayCount)
[in]_horizontalRayCountNumber of vertical rays
References std::endl(), and gzwarn.
◆ SetMaxHorizontalAngle()
template<class T >
void SetMaxHorizontalAngle ( double  _maxHorizontalAngle)
[in]_maxHorizontalAngleMaximum horizontal angle value
◆ SetMaxRange()
template<class T >
void SetMaxRange ( double  _maxRange)
[in]_maxRangeThe maximum range for lidar rays
◆ SetMaxVerticalAngle()
template<class T >
void SetMaxVerticalAngle ( double  _maxVerticalAngle)
[in]_maxVerticalAngleMaximum vertical angle value
◆ SetMinHorizontalAngle()
template<class T >
void SetMinHorizontalAngle ( double  _minHorizontalAngle)
[in]_minHorizontalAngleMinimum horizontal angle value
◆ SetMinRange()
template<class T >
void SetMinRange ( double  _minRange)
[in]_minRangeThe minimum range for lidar rays
◆ SetMinVerticalAngle()
template<class T >
void SetMinVerticalAngle ( double  _minVerticalAngle)
[in]_minVerticalAngleMinimum vertical angle
◆ SetOffset()
template<class T >
void SetOffset ( const gz::math::Pose3d  _offset)
[in]_offsetThe offset of the lidar rays from visual origin
◆ SetPoints() [1/2]
template<class T >
void SetPoints ( const std::vector< double > &  _points)
◆ SetPoints() [2/2]
template<class T >
void SetPoints ( const std::vector< double > &  _points,
const std::vector< gz::math::Color > &  _colors
Reimplemented in OgreLidarVisual.
◆ SetSize()
template<class T >
void SetSize ( double  _size)
[in]_sizeSize of the lidar visualization.
◆ SetType()
template<class T >
void SetType ( const LidarVisualType  _type)
[in]_typeThe type of visualisation for lidar data
◆ SetVerticalRayCount()
template<class T >
void SetVerticalRayCount ( unsigned int  _verticalRayCount)
[in]_verticalRayCountNumber of vertical rays
◆ Size()
template<class T >
double Size ( ) const
SetSize
◆ Type()
template<class T >
LidarVisualType Type ( ) const
The type for lidar visual
template<class T >
void Update ( )
Update the Visual.
◆ VerticalRayCount()
template<class T >
unsigned int VerticalRayCount ( ) const
The number of vertical rays
◆ displayNonHitting
template<class T >
◆ horizontalAngleStep
template<class T >
◆ horizontalCount
template<class T >
◆ lidarVisualType
template<class T >
Initial value:
◆ maxHorizontalAngle
template<class T >
◆ maxRange
template<class T >
double maxRange = 0
Maximum Range.
◆ maxVerticalAngle
template<class T >
◆ minHorizontalAngle
template<class T >
◆ minRange
template<class T >
double minRange = 0
Minimum Range.
◆ minVerticalAngle
template<class T >
◆ offset
template<class T >
Offset of visual.
◆ size
template<class T >
double size = 1.0
◆ verticalAngleStep
template<class T >
◆ verticalCount
template<class T >
