A LidarVisual geometry class. The visual appearance is based on the type specified. More...
#include <gz/rendering/LidarVisual>
virtual ~LidarVisual ()
virtual void ClearPoints ()=0
 Clear the points of the lidar visual.
virtual bool DisplayNonHitting () const =0
 Get if non-hitting rays will be displayed.
virtual unsigned int HorizontalRayCount () const =0
 Get number of horizontal rays.
virtual double MaxHorizontalAngle () const =0
 Get maximum horizontal angle.
virtual double MaxRange () const =0
 Get maximum range of lidar rays.
virtual double MaxVerticalAngle () const =0
 Get minimum vertical angle.
virtual double MinHorizontalAngle () const =0
 Get minimum horizontal angle.
virtual double MinRange () const =0
 Get minimum range of lidar rays.
virtual double MinVerticalAngle () const =0
virtual gz::math::Pose3d Offset () const =0
 Get offset of visual.
virtual unsigned int PointCount () const =0
 Get number of points in laser data.
virtual std::vector< double > Points () const =0
 Get the points in laser data.
virtual void SetDisplayNonHitting (bool _display)=0
 Set if non-hitting rays will be displayed (this does not work for TRIANGLE_STRIPS visual)
virtual void SetHorizontalRayCount (unsigned int _horizontalRayCount)=0
 Set number of horizontal rays.
virtual void SetMaxHorizontalAngle (double _maxHorizontalAngle)=0
 Set maximum horizontal angle.
virtual void SetMaxRange (double _maxRange)=0
 Set maximum range of lidar rays.
virtual void SetMaxVerticalAngle (double _maxVerticalAngle)=0
 Set maximum vertical angle.
virtual void SetMinHorizontalAngle (double _minHorizontalAngle)=0
 Set minimum horizontal angle.
virtual void SetMinRange (double _minRange)=0
 Set minimum range of lidar rays.
virtual void SetMinVerticalAngle (double _minVerticalAngle)=0
 Set minimum vertical angle.
virtual void SetOffset (const gz::math::Pose3d _offset)=0
 Set offset of visual.
virtual void SetPoints (const std::vector< double > &_points)=0
 Set lidar points to be visualised.
virtual void SetPoints (const std::vector< double > &_points, const std::vector< gz::math::Color > &_colors)=0
virtual void SetSize (double _size)=0
 Set size of the lidar visualization, e.g. size of rasterized lidar points in pixels.
virtual void SetType (const LidarVisualType _type)=0
 Set type for lidar visual.
virtual void SetVerticalRayCount (unsigned int _verticalRayCount)=0
 Set number of vertical rays.
 Get size of the lidar visualization.
virtual LidarVisualType Type () const =0
 Get the type for lidar visual.
virtual void Update ()=0
 Update the Visual.
virtual unsigned int VerticalRayCount () const =0
 Get number of vertical rays.
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 LidarVisual ()
◆ LidarVisual()
LidarVisual ( )
◆ ~LidarVisual()
virtual ~LidarVisual ( )
◆ ClearPoints()
virtual void ClearPoints ( )
◆ DisplayNonHitting()
virtual bool DisplayNonHitting ( ) const
Boolean value if non-hitting rays will be displayed
Implemented in BaseLidarVisual< T >, BaseLidarVisual< Ogre2Visual >, and BaseLidarVisual< OgreVisual >.
◆ HorizontalRayCount()
virtual unsigned int HorizontalRayCount ( ) const
The number of horizontal rays
◆ MaxHorizontalAngle()
virtual double MaxHorizontalAngle ( ) const
The maximum horizontal angle value of the lidar visual
◆ MaxRange()
virtual double MaxRange ( ) const
The maximum range for lidar rays
◆ MaxVerticalAngle()
virtual double MaxVerticalAngle ( ) const
The maximum vertical angle value of the lidar visual
◆ MinHorizontalAngle()
virtual double MinHorizontalAngle ( ) const
The minimum horizontal angle value of the lidar visual
◆ MinRange()
virtual double MinRange ( ) const
The minimum range for lidar rays
◆ MinVerticalAngle()
virtual double MinVerticalAngle ( ) const
The minimum vertical angle value of the lidar visual
◆ Offset()
virtual gz::math::Pose3d Offset ( ) const
The offset of the lidar rays from visual origin
◆ PointCount()
Implemented in BaseLidarVisual< T >, BaseLidarVisual< Ogre2Visual >, BaseLidarVisual< OgreVisual >, OgreLidarVisual, and Ogre2LidarVisual.
◆ Points()
virtual std::vector< double > Points ( ) const
The points in the laser data
◆ SetDisplayNonHitting()
virtual void SetDisplayNonHitting ( bool  _display)
[in]_displayBoolean value to display non hitting visuals
◆ SetHorizontalRayCount()
virtual void SetHorizontalRayCount ( unsigned int  _horizontalRayCount)
[in]_horizontalRayCountNumber of vertical rays
◆ SetMaxHorizontalAngle()
virtual void SetMaxHorizontalAngle ( double  _maxHorizontalAngle)
[in]_maxHorizontalAngleMaximum horizontal angle value
◆ SetMaxRange()
virtual void SetMaxRange ( double  _maxRange)
[in]_maxRangeThe maximum range for lidar rays
◆ SetMaxVerticalAngle()
virtual void SetMaxVerticalAngle ( double  _maxVerticalAngle)
[in]_maxVerticalAngleMaximum vertical angle value
◆ SetMinHorizontalAngle()
virtual void SetMinHorizontalAngle ( double  _minHorizontalAngle)
[in]_minHorizontalAngleMinimum horizontal angle value
◆ SetMinRange()
virtual void SetMinRange ( double  _minRange)
[in]_minRangeThe minimum range for lidar rays
◆ SetMinVerticalAngle()
virtual void SetMinVerticalAngle ( double  _minVerticalAngle)
[in]_minVerticalAngleMinimum vertical angle
◆ SetOffset()
virtual void SetOffset ( const gz::math::Pose3d  _offset)
[in]_offsetThe offset of the lidar rays from visual origin
◆ SetPoints() [1/2]
◆ SetPoints() [2/2]
virtual void SetPoints ( const std::vector< double > &  _points,
const std::vector< gz::math::Color > &  _colors
Implemented in BaseLidarVisual< T >, BaseLidarVisual< Ogre2Visual >, BaseLidarVisual< OgreVisual >, and OgreLidarVisual.
◆ SetSize()
virtual void SetSize ( double  _size)
[in]_sizeSize of the lidar visualization.
◆ SetType()
virtual void SetType ( const LidarVisualType  _type)
[in]_typeThe type of visualisation for lidar data
◆ SetVerticalRayCount()
virtual void SetVerticalRayCount ( unsigned int  _verticalRayCount)
[in]_verticalRayCountNumber of vertical rays
◆ Size()
virtual double Size ( ) const
SetSize
◆ Type()
virtual LidarVisualType Type ( ) const
The type for lidar visual
virtual void Update ( )
◆ VerticalRayCount()
virtual unsigned int VerticalRayCount ( ) const
The number of vertical rays
