Ogre implementation of a Lidar Visual. More...
#include <OgreLidarVisual.hh>
virtual ~OgreLidarVisual ()
 Clear the points of the lidar visual.
 Get number of points in laser data.
 Get the points in laser data.
 Set lidar points to be visualised.
virtual void SetPoints (const std::vector< double > &_points, const std::vector< gz::math::Color > &_colors) override
 Update the Visual.
- Public Member Functions inherited from BaseLidarVisual< OgreVisual >
virtual ~BaseLidarVisual ()
 Create predefined materials for lidar visual.
 Get if non-hitting rays will be displayed.
 Get number of horizontal rays.
 Get maximum horizontal angle.
 Get maximum range of lidar rays.
 Get minimum vertical angle.
 Get minimum horizontal angle.
 Get minimum range of lidar rays.
virtual gz::math::Pose3d Offset () const override
 Get offset of visual.
 Set if non-hitting rays will be displayed (this does not work for TRIANGLE_STRIPS visual)
 Set number of horizontal rays.
 Set maximum horizontal angle.
 Set maximum range of lidar rays.
 Set maximum vertical angle.
 Set minimum horizontal angle.
 Set minimum range of lidar rays.
 Set minimum vertical angle.
virtual void SetOffset (const gz::math::Pose3d _offset) override
 Set offset of visual.
 Set size of the lidar visualization, e.g. size of rasterized lidar points in pixels.
 Set type for lidar visual.
 Set number of vertical rays.
 Get size of the lidar visualization.
 Get the type for lidar visual.
 Get number of vertical rays.
virtual ~LidarVisual ()
virtual ~OgreVisual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreLidarVisual ()
- Protected Member Functions inherited from BaseLidarVisual< OgreVisual >
 BaseLidarVisual ()
 LidarVisual ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseLidarVisual< OgreVisual >
bool displayNonHitting
 Option to display non-hitting rays.
double horizontalAngleStep
 Angle between two horizontal rays.
unsigned int horizontalCount
 Horizontal laser count.
 Type of lidar visualisation.
double maxHorizontalAngle
 Horizontal maximum angle.
double maxRange
 Maximum Range.
double maxVerticalAngle
 Vertical maximum angle.
double minHorizontalAngle
 Horizontal minimal angle.
double minRange
 Minimum Range.
double minVerticalAngle
 Vertical minimal angle.
gz::math::Pose3d offset
 Offset of visual.
double size
 Size of lidar visualisation.
double verticalAngleStep
 Angle between two vertical rays.
unsigned int verticalCount
 Vertical laser count.
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreLidarVisual()
OgreLidarVisual ( )
◆ ~OgreLidarVisual()
virtual ~OgreLidarVisual ( )
◆ ClearPoints()
virtual void ClearPoints ( )
Reimplemented from BaseLidarVisual< OgreVisual >.
◆ PointCount()
◆ Points()
virtual std::vector< double > Points ( ) const
The points in the laser data
◆ SetPoints() [1/2]
◆ SetPoints() [2/2]
virtual void SetPoints ( const std::vector< double > &  _points,
const std::vector< gz::math::Color > &  _colors
◆ SetVisible()
Implements Visual.
virtual void Update ( )
Update the Visual.
