BaseAxisVisual< T > Class Template Reference
#include <BaseAxisVisual.hh>
virtual ~BaseAxisVisual ()
 Get the local scale.
 Set the local scale.
 set true to show the axis heads, false otherwise
 set true to show the specified axis head, false otherwise
virtual ~AxisVisual ()
virtual ~CompositeVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseAxisVisual ()
◆ BaseAxisVisual()
template<class T >
BaseAxisVisual ( )
◆ ~BaseAxisVisual()
template<class T >
~BaseAxisVisual ( )
template<class T >
void Destroy ( )
References std::dynamic_pointer_cast().
template<class T >
void Init ( )
◆ LocalScale()
template<class T >
math::Vector3d LocalScale ( ) const
The local scale
Implements Node.
References Vector3< typename T >::Zero.
◆ SetLocalScale()
template<class T >
[in]_scaleNew local scale
Implements Node.
References Vector3< typename T >::X(), Vector3< typename T >::Y(), and Vector3< typename T >::Z().
◆ SetVisible()
template<class T >
Implements Visual.
◆ ShowAxisHead() [1/2]
template<class T >
void ShowAxisHead ( bool  _b)
[in]_btrue to show the axis heads, false otherwise
Implements AxisVisual.
◆ ShowAxisHead() [2/2]
template<class T >
void ShowAxisHead ( unsigned int  _axis,
bool  _b
[in]_axisAxis index. 0: x, 1: y, 2: z
[in]_btrue to show the specified axis head, false otherwise
