AxisVisual Class Referenceabstract
Represents a axis composite visual. More...
#include <gz/rendering/AxisVisual.hh>
virtual ~AxisVisual ()
virtual void ShowAxisHead (bool _b)=0
 set true to show the axis heads, false otherwise
virtual void ShowAxisHead (unsigned int _axis, bool _b)=0
 set true to show the specified axis head, false otherwise
virtual ~CompositeVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
◆ ~AxisVisual()
virtual ~AxisVisual ( )
◆ ShowAxisHead() [1/2]
virtual void ShowAxisHead ( bool  _b)
[in]_btrue to show the axis heads, false otherwise
Implemented in BaseAxisVisual< T >, BaseAxisVisual< Ogre2Visual >, and BaseAxisVisual< OgreVisual >.
◆ ShowAxisHead() [2/2]
virtual void ShowAxisHead ( unsigned int  _axis,
bool  _b
[in]_axisAxis index. 0: x, 1: y, 2: z
[in]_btrue to show the specified axis head, false otherwise
