BaseInertiaVisual< T > Class Template Reference
Base implementation of an inertia visual. More...
#include <BaseInertiaVisual.hh>
virtual ~BaseInertiaVisual ()
virtual VisualPtr BoxVisual () const override
 Get the box visual.
virtual void Load (const gz::math::Pose3d &, const gz::math::Vector3d &) override
 Load the Inertia visual from its pose and scale.
 Set the inertial component of the visual.
virtual ~InertiaVisual ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
template<class T>
class gz::rendering::BaseInertiaVisual< T >
◆ BaseInertiaVisual()
template<class T >
BaseInertiaVisual ( )
◆ ~BaseInertiaVisual()
template<class T >
~BaseInertiaVisual ( )
◆ BoxVisual()
template<class T >
VisualPtr BoxVisual ( ) const
Get the box visual.
Pointer to the box visual
Implements InertiaVisual.
Reimplemented in OgreInertiaVisual, and Ogre2InertiaVisual.
template<class T >
void Init ( )
◆ Load()
template<class T >
void Load ( const gz::math::Pose3d &  _pose,
const gz::math::Vector3d &  _scale
template<class T >
void PreRender ( )
◆ SetInertial()
template<class T >
void SetInertial ( const gz::math::Inertiald &  _inertial)
References gzlog, Inertial< typename T >::MassMatrix(), and Inertial< typename T >::Pose().
