#include <OgreCamera.hh>
virtual ~OgreCamera ()
virtual math::Color BackgroundColor () const
virtual Ogre::Camera * Camera () const override
 Access the Ogre::Camera object.
 Create a render window.
double FarClip () const
 Get the far clip distance.
double NearClip () const
 Get the near clip distance.
virtual void SetBackgroundColor (const math::Color &_color)
void SetVFOV (double cameraVFOV) const
 Set visibility mask.
virtual ~BaseCamera ()
 Get a render passes by index.
 Set the image pixel format.
virtual ~Camera ()
 Sensor.
virtual ~OgreSensor ()
virtual ~BaseSensor ()
 Get visibility mask.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
- Public Member Functions inherited from OgreObjectInterface
virtual ~OgreObjectInterface ()
 Access to an Ogre::MovableObject.
 OgreCamera ()
void DestroyRenderTexture ()
 Destroy render texture created by CreateRenderTexture() Note: It's not virtual.
virtual void SetSelectionBuffer ()
void SyncOgreCameraAspectRatio ()
 Synchronizes every setting that depends on AspectRatio with Ogre's camera.
 BaseCamera ()
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
math::Color backgroundColor
OgreRenderTargetPtr renderTexture
OgreSelectionBuffer * selectionBuffer = nullptr
unsigned int antiAliasing
 Anti-aliasing.
double aspect
 Aspect ratio.
double farClip
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain
bool followWorldFrame
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
 Camera's visibility mask.
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreCamera()
OgreCamera ( )
◆ ~OgreCamera()
virtual ~OgreCamera ( )
◆ AntiAliasing()
◆ AspectRatio()
Remarks
If SetAspectRatio() gets called with an input <= 0 this function returns the Aspect Ratio autocalculated based on the camera's dimensions.
The camera's aspect ratio. This value is always in range (0; inf) unless the dimensions are invalid (e.g. 0 width or height, NaN resolution, etc)
◆ BackgroundColor()
◆ Camera()
virtual Ogre::Camera * Camera ( ) const
Implements OgreObjectInterface.
◆ CreateRenderTexture()
◆ CreateRenderWindow()
◆ DestroyRenderTexture()
void DestroyRenderTexture ( )
◆ FarClip()
double FarClip ( ) const
Far clip distance
◆ HFOV()
virtual math::Angle HFOV ( ) const
Reimplemented from OgreNode.
◆ NearClip()
double NearClip ( ) const
Near clip distance
◆ ProjectionMatrix()
Camera projection matrix
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
◆ RenderTextureGLId()
Texture Id of type GLuint.
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
[in]_ratioThe camera's aspect ratio
◆ SetBackgroundColor()
◆ SetFarClipPlane()
◆ SetHFOV()
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetProjectionMatrix()
◆ SetProjectionType()
virtual void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
◆ SetSelectionBuffer()
virtual void SetSelectionBuffer ( )
◆ SetVFOV()
void SetVFOV ( double  cameraVFOV) const
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implements Sensor.
◆ SyncOgreCameraAspectRatio()
void SyncOgreCameraAspectRatio ( )
◆ ViewMatrix()
Camera view matrix
◆ VisualAt()
virtual VisualPtr VisualAt ( const gz::math::Vector2i &  _mousePos)
◆ backgroundColor
◆ ogreCamera
◆ renderTexture
◆ selectionBuffer
OgreSelectionBuffer* selectionBuffer = nullptr
