#include <OgreSensor.hh>
virtual ~OgreSensor ()
virtual ~BaseSensor ()
 Set visibility mask.
 Get visibility mask.
 Sensor.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreSensor ()
 BaseSensor ()
 OgreNode ()
uint32_t visibilityMask
 Camera's visibility mask.
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreSensor()
OgreSensor ( )
◆ ~OgreSensor()
virtual ~OgreSensor ( )
