COMVisual Class Referenceabstract
Represents a center of mass visual. More...
#include <COMVisual.hh>
virtual ~COMVisual ()
virtual gz::math::Pose3d InertiaPose () const =0
 Get the inertia pose.
virtual double Mass () const =0
 Get the mass of the parent.
virtual void SetInertial (const gz::math::Inertiald &_inertial)=0
 Set the inertial component of the visual.
virtual void SetMass (double _mass)=0
 Set the mass of the parent.
virtual VisualPtr SphereVisual () const =0
 Get the sphere visual.
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
gz/rendering/COMVisual.hh
◆ ~COMVisual()
virtual ~COMVisual ( )
◆ InertiaPose()
virtual gz::math::Pose3d InertiaPose ( ) const
Inertia pose in parent frame.
Implemented in BaseCOMVisual< T >, BaseCOMVisual< Ogre2Visual >, and BaseCOMVisual< OgreVisual >.
◆ Mass()
virtual double Mass ( ) const
Parent mass
◆ SetInertial()
virtual void SetInertial ( const gz::math::Inertiald &  _inertial)
◆ SetMass()
virtual void SetMass ( double  _mass)
[in]_massParent mass
◆ SphereVisual()
Pointer to the sphere visual
Implemented in BaseCOMVisual< T >, BaseCOMVisual< Ogre2Visual >, BaseCOMVisual< OgreVisual >, OgreCOMVisual, and Ogre2COMVisual.
