Ogre2.x implementation of the camera class. More...
#include <Ogre2Camera.hh>
virtual ~Ogre2Camera ()
virtual math::Color BackgroundColor () const
virtual MaterialPtr BackgroundMaterial () const
 Get the background material of this camera.
 Create a render window.
virtual Ogre::Camera * OgreCamera () const override
 Access the Ogre::Camera object.
Ogre2SelectionBuffer * SelectionBuffer () const
 Get the selection buffer object.
virtual void SetBackgroundColor (const math::Color &_color)
virtual void SetBackgroundMaterial (MaterialPtr _material)
 Set the background material of this camera.
void SetShadowsDirty () override
 Set visibility mask.
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
 Get a render passes by index.
 Set the image pixel format.
virtual ~Camera ()
 Sensor.
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Get visibility mask.
virtual ~Ogre2Node ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
- Public Member Functions inherited from Ogre2ObjectInterface
virtual ~Ogre2ObjectInterface ()
 Access to an Ogre::MovableObject.
 Ogre2Camera ()
 Create a render texture for the camera for offscreen rendering.
void DestroyRenderTexture ()
 Destroy render texture created by CreateRenderTexture() Note: It's not virtual.
virtual void SetSelectionBuffer ()
 Create and set selection buffer object TODO(anyone) to be implemented.
void SyncOgreCameraAspectRatio ()
 Synchronizes every setting that depends on AspectRatio with Ogre's camera.
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node.
math::Color backgroundColor
 Color of background.
 Pointer to ogre camera object.
Ogre2RenderTargetPtr renderTexture
 Pointer to render texture.
Ogre2SelectionBuffer * selectionBuffer = nullptr
 Selection buffer object for entity picking.
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing.
double aspect
 Aspect ratio.
double farClip
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain
bool followWorldFrame
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
 Camera's visibility mask.
Ogre2NodeStorePtr children
 A list of child nodes.
Ogre2NodePtr parent
 Pointer to the ogre scene.
◆ Ogre2Camera()
Ogre2Camera ( )
◆ ~Ogre2Camera()
virtual ~Ogre2Camera ( )
◆ AntiAliasing()
Reimplemented from BaseCamera< Ogre2Sensor >.
◆ AspectRatio()
Remarks
If SetAspectRatio() gets called with an input <= 0 this function returns the Aspect Ratio autocalculated based on the camera's dimensions.
The camera's aspect ratio. This value is always in range (0; inf) unless the dimensions are invalid (e.g. 0 width or height, NaN resolution, etc)
◆ BackgroundColor()
◆ BackgroundMaterial()
virtual MaterialPtr BackgroundMaterial ( ) const
Background material of this camera
◆ CreateRenderTexture()
◆ CreateRenderWindow()
◆ DestroyRenderTexture()
void DestroyRenderTexture ( )
◆ HFOV()
virtual math::Angle HFOV ( ) const
Reimplemented from Ogre2Node.
◆ OgreCamera()
virtual Ogre::Camera * OgreCamera ( ) const
Implements Ogre2ObjectInterface.
◆ PrepareForExternalSampling()
virtual void PrepareForExternalSampling ( )
◆ ProjectionMatrix()
Camera projection matrix
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
◆ RenderTextureGLId()
Texture Id of type GLuint.
◆ RenderTextureMetalId()
virtual void RenderTextureMetalId ( void *  _textureIdPtr) const
◆ SelectionBuffer()
Ogre2SelectionBuffer * SelectionBuffer ( ) const
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
[in]_ratioThe camera's aspect ratio
◆ SetBackgroundColor()
◆ SetBackgroundMaterial()
virtual void SetBackgroundMaterial ( MaterialPtr  _material)
[in]_materialMaterial to set the background to
◆ SetFarClipPlane()
◆ SetHFOV()
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetProjectionMatrix()
◆ SetProjectionType()
virtual void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
◆ SetSelectionBuffer()
virtual void SetSelectionBuffer ( )
◆ SetShadowsDirty()
void SetShadowsDirty ( )
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implements Sensor.
◆ SyncOgreCameraAspectRatio()
void SyncOgreCameraAspectRatio ( )
◆ ViewMatrix()
Camera view matrix
◆ VisualAt()
virtual VisualPtr VisualAt ( const gz::math::Vector2i &  _mousePos)
◆ backgroundColor
◆ ogreCamera
◆ renderTexture
◆ selectionBuffer
Ogre2SelectionBuffer* selectionBuffer = nullptr
