BaseDepthCamera< T > Class Template Reference
#include <BaseDepthCamera.hh>
 ~BaseDepthCamera () override
gz::common::ConnectionPtr ConnectNewDepthFrame (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect to the new depth image signal.
virtual gz::common::ConnectionPtr ConnectNewRGBPointCloud (std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)
void CreateDepthTexture () override
 Create a texture which will hold the depth data.
const float * DepthData () const override
 All things needed to get back z buffer for depth data.
- Public Member Functions inherited from DepthCamera
virtual ~DepthCamera ()
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud (std::function< void(const float *_pointCloud, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)> _subscriber)=0
 Connect to the new rgb point cloud signal.
virtual ~Camera ()
virtual void Render ()=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
 BaseDepthCamera ()
 BaseCamera ()
- Public Types inherited from DepthCamera
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseDepthCamera()
template<class T >
BaseDepthCamera ( )
◆ ~BaseDepthCamera()
template<class T >
~BaseDepthCamera ( )
◆ ConnectNewDepthFrame()
template<class T >
gz::common::ConnectionPtr ConnectNewDepthFrame ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Implements DepthCamera.
Reimplemented in OgreDepthCamera, and Ogre2DepthCamera.
◆ ConnectNewRGBPointCloud()
template<class T >
gz::common::ConnectionPtr ConnectNewRGBPointCloud ( std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
◆ CreateDepthTexture()
template<class T >
void CreateDepthTexture ( )
◆ DepthData()
template<class T >
const float * DepthData ( ) const
The z-buffer as a float array
The documentation for this class was generated from the following files:
