#include <BaseGpuRays.hh>
virtual ~BaseGpuRays ()
virtual gz::math::Angle AngleMax () const override
 Get maximal horizontal angle value.
virtual gz::math::Angle AngleMin () const override
 Get minimal horizontal angle value.
 Get the number of channels used to store the ray data.
 Get behaviour for data values outside of camera range.
virtual void Copy (float *_dataDest) override
 Copy to the specified memory direction the gpu rays data.
 All things needed to get back z buffer for gpu rays data.
virtual double HorizontalResolution () const override
 Get the horizontal resolution. This number is multiplied by RayCount to calculate RangeCount, which is the the number range data points.
 Gets if sensor is horizontal.
 Get hoizontal range count, i.e. ray count * horz resolution.
 Get the ray count ratio (equivalent to aspect ratio)
 Get horizontal quantity of rays.
virtual RenderTargetPtr RenderTarget () const override=0
 Pointer to the render target.
 Set maximal horizontal angle value.
 Set minimal horizontal angle value.
 Configure behaviour for data values outside of camera range.
virtual void SetHorizontalResolution (double _resolution) override
 Set the horizontal resolution. This number is multiplied by RayCount to calculate RangeCount, which is the the number range data points.
 Set sensor horizontal or vertical.
 Set horizontal quantity of rays.
 Sets the ray count ratio (equivalent to aspect ratio)
 Set maximal vertical angle value.
 Set minimal vertical angle value.
 Set vertical quantity of rays.
virtual void SetVerticalResolution (double _resolution) override
 Set the vertical resolution. This number is multiplied by VerticalRayCount to calculate VerticalRangeCount, which is the the number vertical range data points.
 Set the vertical fov.
virtual gz::math::Angle VerticalAngleMax () const override
 Get maximal vertical angle value.
virtual gz::math::Angle VerticalAngleMin () const override
 Get minimal vertical angle value.
 Get vertical range count, i.e. ray count * vert resolution.
 Get vertical quantity of rays.
virtual double VerticalResolution () const override
 Get the vertical resolution. This number is multiplied by VerticalRayCount to calculate VerticalRangeCount, which is the the number vertical range data points.
virtual ~GpuRays ()
 Connect to a gpu rays frame signal.
virtual ~Camera ()
virtual void Render ()=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
Public Attributes
bool clamping = false
 True if data values are clamped to camera clip distances,.
float dataMaxVal = gz::math::INF_D
 maximum value used for data outside sensor range
float dataMinVal = -gz::math::INF_D
 minimum value used for data outside sensor range
 BaseGpuRays ()
 BaseCamera ()
unsigned int channels = 1u
 Number of channels used to store the data.
double hResolution = 1
 Resolution of horizontal rays.
int hSamples = 0
 Quantity of horizontal rays.
bool isHorizontal = true
 True if the sensor is horizontal only.
double maxAngle = 0
 Horizontal maximal angle.
double minAngle = 0
 Horizontal minimal angle.
double rangeCountRatio = 0
 Range count ratio.
double rayCountRatio = 0
 Ray count ratio.
math::Angle vfov
 Vertical field-of-view.
double vMaxAngle = 0
 Vertical maximal angle.
double vMinAngle = 0
 Vertical minimal angle.
double vResolution = 1
 Resolution of vertical rays.
int vSamples = 0
 Quantity of vertical rays.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseGpuRays()
template<class T >
BaseGpuRays ( )
◆ ~BaseGpuRays()
template<class T >
~BaseGpuRays ( )
◆ AngleMax()
template<class T >
gz::math::Angle AngleMax ( ) const
Implements GpuRays.
◆ AngleMin()
template<class T >
gz::math::Angle AngleMin ( ) const
Implements GpuRays.
◆ Channels()
template<class T >
unsigned int Channels ( ) const
Channel count.
Implements GpuRays.
◆ Clamp()
template<class T >
bool Clamp ( ) const
True if data values are clampped to camera clip distances,
Implements GpuRays.
◆ ConnectNewGpuRaysFrame()
template<class T >
gz::common::ConnectionPtr ConnectNewGpuRaysFrame ( std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &_format)>  _subscriber)
◆ Copy()
template<class T >
void Copy ( float *  _data)
Implements GpuRays.
Reimplemented in OgreGpuRays, and Ogre2GpuRays.
◆ Data()
template<class T >
const float * Data ( ) const
Array of gpu rays data.
Implements GpuRays.
◆ HorizontalResolution()
template<class T >
double HorizontalResolution ( ) const
RayCount()
The horizontal resolution
Implements GpuRays.
◆ IsHorizontal()
template<class T >
bool IsHorizontal ( ) const
Implements GpuRays.
◆ RangeCount()
template<class T >
int RangeCount ( ) const
Implements GpuRays.
◆ RangeCountRatio()
template<class T >
double RangeCountRatio ( ) const
The ray count ratio (equivalent to aspect ratio)
Implements GpuRays.
◆ RayCount()
template<class T >
int RayCount ( ) const
Implements GpuRays.
◆ RayCountRatio()
template<class T >
double RayCountRatio ( ) const
Implements GpuRays.
◆ RenderTarget()
template<class T >
overridepure virtual
Implements BaseCamera< T >.
Implemented in OgreGpuRays, and Ogre2GpuRays.
◆ SetAngleMax()
template<class T >
void SetAngleMax ( double  _angle)
Implements GpuRays.
◆ SetAngleMin()
template<class T >
void SetAngleMin ( double  _angle)
Implements GpuRays.
◆ SetClamp()
template<class T >
void SetClamp ( bool  _clamp)
[in]_clampTrue to clamp data to camera clip distances,
Implements GpuRays.
References gz::math::INF_D.
◆ SetHorizontalResolution()
template<class T >
void SetHorizontalResolution ( double  _resolution)
RayCount()
[in]_resolutionThe new horizontal resolution. The absolute value of this parameter is used to prevent a negative resolution value.
Implements GpuRays.
References std::dynamic_pointer_cast().
◆ SetIsHorizontal()
template<class T >
void SetIsHorizontal ( const bool  _horizontal)
[in]_horizontalTrue if horizontal, false if not
Implements GpuRays.
◆ SetRayCount()
template<class T >
void SetRayCount ( int  _samples)
Implements GpuRays.
◆ SetRayCountRatio()
template<class T >
void SetRayCountRatio ( const double  _rayCountRatio)
[in]_rayCountRatioray count ratio (equivalent to aspect ratio)
Implements GpuRays.
◆ SetVerticalAngleMax()
template<class T >
void SetVerticalAngleMax ( const double  _angle)
Implements GpuRays.
◆ SetVerticalAngleMin()
template<class T >
void SetVerticalAngleMin ( const double  _angle)
Implements GpuRays.
◆ SetVerticalRayCount()
template<class T >
void SetVerticalRayCount ( int  _samples)
Implements GpuRays.
◆ SetVerticalResolution()
template<class T >
void SetVerticalResolution ( double  _resolution)
[in]_resolutionThe new vertical resolution. The absolute value of this parameter is used to prevent a negative resolution value.
VerticalRayCount()
Implements GpuRays.
◆ SetVFOV()
template<class T >
void SetVFOV ( const math::Angle &  _vfov)
[in]_vfovvertical fov
◆ VerticalAngleMax()
template<class T >
gz::math::Angle VerticalAngleMax ( ) const
Implements GpuRays.
◆ VerticalAngleMin()
template<class T >
gz::math::Angle VerticalAngleMin ( ) const
Implements GpuRays.
◆ VerticalRangeCount()
template<class T >
int VerticalRangeCount ( ) const
Implements GpuRays.
◆ VerticalRayCount()
template<class T >
int VerticalRayCount ( ) const
Implements GpuRays.
◆ VerticalResolution()
template<class T >
double VerticalResolution ( ) const
The vertical resolution.
VerticalRayCount()
Implements GpuRays.
◆ VFOV()
template<class T >
math::Angle VFOV ( ) const
The vertical field of view of the gpu rays.
Implements GpuRays.
◆ channels
template<class T >
◆ clamping
template<class T >
◆ dataMaxVal
template<class T >
◆ dataMinVal
template<class T >
◆ hResolution
template<class T >
◆ hSamples
template<class T >
int hSamples = 0
◆ isHorizontal
template<class T >
◆ maxAngle
template<class T >
double maxAngle = 0
◆ minAngle
template<class T >
double minAngle = 0
◆ rangeCountRatio
template<class T >
Range count ratio.
◆ rayCountRatio
template<class T >
Ray count ratio.
◆ vfov
template<class T >
math::Angle vfov
◆ vMaxAngle
template<class T >
◆ vMinAngle
template<class T >
◆ vResolution
template<class T >
◆ vSamples
template<class T >
int vSamples = 0
