GpuRays Class Referenceabstract
Generate depth ray data. More...
#include <gz/rendering/GpuRays.hh>
Public Types
virtual ~GpuRays ()
virtual gz::math::Angle AngleMax () const =0
 Get maximal horizontal angle value.
virtual gz::math::Angle AngleMin () const =0
 Get minimal horizontal angle value.
virtual unsigned int Channels () const =0
 Get the number of channels used to store the ray data.
virtual bool Clamp () const =0
 Get behaviour for data values outside of camera range.
 Connect to a gpu rays frame signal.
virtual void Copy (float *_data)=0
 Copy to the specified memory direction the gpu rays data.
virtual const float * Data () const =0
 All things needed to get back z buffer for gpu rays data.
virtual double HorizontalResolution () const =0
 Get the horizontal resolution. This number is multiplied by RayCount to calculate RangeCount, which is the the number range data points.
virtual bool IsHorizontal () const =0
 Gets if sensor is horizontal.
virtual int RangeCount () const =0
 Get hoizontal range count, i.e. ray count * horz resolution.
virtual double RangeCountRatio () const =0
 Get the ray count ratio (equivalent to aspect ratio)
virtual int RayCount () const =0
 Get horizontal quantity of rays.
virtual double RayCountRatio () const =0
virtual void SetAngleMax (double _angle)=0
 Set maximal horizontal angle value.
virtual void SetAngleMin (double _angle)=0
 Set minimal horizontal angle value.
virtual void SetClamp (const bool _clamp)=0
 Configure behaviour for data values outside of camera range.
virtual void SetHorizontalResolution (double _resolution)=0
 Set the horizontal resolution. This number is multiplied by RayCount to calculate RangeCount, which is the the number range data points.
virtual void SetIsHorizontal (const bool _horizontal)=0
 Set sensor horizontal or vertical.
virtual void SetRayCount (int _samples)=0
 Set horizontal quantity of rays.
virtual void SetRayCountRatio (const double _rayCountRatio)=0
 Sets the ray count ratio (equivalent to aspect ratio)
virtual void SetVerticalAngleMax (const double _angle)=0
 Set maximal vertical angle value.
virtual void SetVerticalAngleMin (const double _angle)=0
 Set minimal vertical angle value.
virtual void SetVerticalRayCount (int _samples)=0
 Set vertical quantity of rays.
virtual void SetVerticalResolution (double _resolution)=0
 Set the vertical resolution. This number is multiplied by VerticalRayCount to calculate VerticalRangeCount, which is the the number vertical range data points.
virtual gz::math::Angle VerticalAngleMax () const =0
 Get maximal vertical angle value.
virtual gz::math::Angle VerticalAngleMin () const =0
 Get minimal vertical angle value.
virtual int VerticalRangeCount () const =0
 Get vertical range count, i.e. ray count * vert resolution.
virtual int VerticalRayCount () const =0
 Get vertical quantity of rays.
virtual double VerticalResolution () const =0
 Get the vertical resolution. This number is multiplied by VerticalRayCount to calculate VerticalRangeCount, which is the the number vertical range data points.
virtual math::Angle VFOV () const =0
virtual ~Camera ()
 Create a render window.
virtual void PrepareForExternalSampling ()=0
virtual void Render ()=0
 Get a render passes by index.
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format, bool _reinterpretable=false)=0
 Set the image pixel format.
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
Member Typedef Documentation
◆ NewFrameListener
typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener
◆ ~GpuRays()
virtual ~GpuRays ( )
◆ AngleMax()
virtual gz::math::Angle AngleMax ( ) const
Implemented in BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, and BaseGpuRays< OgreSensor >.
◆ AngleMin()
virtual gz::math::Angle AngleMin ( ) const
◆ Channels()
virtual unsigned int Channels ( ) const
Channel count.
◆ Clamp()
virtual bool Clamp ( ) const
True if data values are clampped to camera clip distances,
◆ ConnectNewGpuRaysFrame()
virtual common::ConnectionPtr ConnectNewGpuRaysFrame ( std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &)>  _subscriber)
[in]_subscriberCallback that is called when a new image is generated. The callback function parameters are: _frame: Image frame is an array of floats. Size is equal to width * height * channels Each gpu rays reading occupies 3 floats Index 0: depth value Index 1: retro value Index 2: 0. Not used _width: Width of image, i.e. number of data in the horizontal scan _height: Height o image, i.e. number of scans in vertical direction _channels: Number of channels, i.e. 3 floats per gpu rays reading _format: Pixel format of the image frame.
A pointer to the connection. This must be kept in scope.
◆ Copy()
virtual void Copy ( float *  _data)
Implemented in OgreGpuRays, Ogre2GpuRays, BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, and BaseGpuRays< OgreSensor >.
◆ Data()
virtual const float * Data ( ) const
Array of gpu rays data.
Implemented in BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, BaseGpuRays< OgreSensor >, OgreGpuRays, and Ogre2GpuRays.
◆ HorizontalResolution()
virtual double HorizontalResolution ( ) const
RayCount()
The horizontal resolution
◆ IsHorizontal()
virtual bool IsHorizontal ( ) const
◆ RangeCount()
virtual int RangeCount ( ) const
◆ RangeCountRatio()
virtual double RangeCountRatio ( ) const
The ray count ratio (equivalent to aspect ratio)
◆ RayCount()
virtual int RayCount ( ) const
◆ RayCountRatio()
virtual double RayCountRatio ( ) const
◆ SetAngleMax()
virtual void SetAngleMax ( double  _angle)
◆ SetAngleMin()
virtual void SetAngleMin ( double  _angle)
◆ SetClamp()
virtual void SetClamp ( const bool  _clamp)
[in]_clampTrue to clamp data to camera clip distances,
◆ SetHorizontalResolution()
virtual void SetHorizontalResolution ( double  _resolution)
RayCount()
[in]_resolutionThe new horizontal resolution. The absolute value of this parameter is used to prevent a negative resolution value.
◆ SetIsHorizontal()
virtual void SetIsHorizontal ( const bool  _horizontal)
[in]_horizontalTrue if horizontal, false if not
◆ SetRayCount()
virtual void SetRayCount ( int  _samples)
◆ SetRayCountRatio()
virtual void SetRayCountRatio ( const double  _rayCountRatio)
[in]_rayCountRatioray count ratio (equivalent to aspect ratio)
◆ SetVerticalAngleMax()
virtual void SetVerticalAngleMax ( const double  _angle)
◆ SetVerticalAngleMin()
virtual void SetVerticalAngleMin ( const double  _angle)
◆ SetVerticalRayCount()
virtual void SetVerticalRayCount ( int  _samples)
◆ SetVerticalResolution()
virtual void SetVerticalResolution ( double  _resolution)
[in]_resolutionThe new vertical resolution. The absolute value of this parameter is used to prevent a negative resolution value.
VerticalRayCount()
◆ VerticalAngleMax()
virtual gz::math::Angle VerticalAngleMax ( ) const
◆ VerticalAngleMin()
virtual gz::math::Angle VerticalAngleMin ( ) const
◆ VerticalRangeCount()
virtual int VerticalRangeCount ( ) const
◆ VerticalRayCount()
virtual int VerticalRayCount ( ) const
◆ VerticalResolution()
virtual double VerticalResolution ( ) const
The vertical resolution.
VerticalRayCount()
◆ VFOV()
virtual math::Angle VFOV ( ) const
The vertical field of view of the gpu rays.
