BaseBoundingBoxCamera< T > Class Template Referenceabstract
#include <BaseBoundingBoxCamera.hh>
 ~BaseBoundingBoxCamera () override
const std::vector< BoundingBox > & BoundingBoxData () const override
 Get the BoundingBox data.
gz::common::ConnectionPtr ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)> _subscriber) override=0
 Connect to the new BoundingBox info.
void DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const override=0
 Draw a bounding box on the given image.
void SetBoundingBoxType (BoundingBoxType _type) override
 Set BoundingBox Type (Visible / Full)
BoundingBoxType Type () const override
 Get the BoundingBox Type (Visible / Full)
- Public Member Functions inherited from BoundingBoxCamera
virtual ~BoundingBoxCamera ()
virtual ~Camera ()
virtual void Render ()=0
 Sensor.
 Set visibility mask.
 Get visibility mask.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
virtual ~BaseCamera ()
 Create a render window.
 Get a render passes by index.
 Set the image pixel format.
 BaseCamera ()
std::vector< BoundingBox > boundingBoxes
 The bounding box data.
BoundingBoxType type = BoundingBoxType::BBT_FULLBOX2D
 The bounding box type.
 Anti-aliasing.
double aspect = 1.3333333
 Aspect ratio.
double farClip = 1000.0
 Far clipping plane distance.
NodePtr followNode
 Target node to follow.
math::Vector3d followOffset
double followPGain = 1.0
bool followWorldFrame = false
 Follow target in world frame.
math::Angle hfov
ImagePtr imageBuffer
double nearClip = 0.01
 Near clipping plane distance.
 Custom projection matrix.
 Camera projection type.
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain = 1.0
bool trackWorldFrame = false
◆ BaseBoundingBoxCamera()
template<class T >
BaseBoundingBoxCamera ( )
◆ ~BaseBoundingBoxCamera()
template<class T >
~BaseBoundingBoxCamera ( )
◆ BoundingBoxData()
template<class T >
const std::vector< BoundingBox > & BoundingBoxData ( ) const
Buffer of bounding boxes info (label, minX, minY, maxX, maxY). If the camera's bounding box type is 3D, minZ and maxZ are also defined)
Implements BoundingBoxCamera.
Reimplemented in Ogre2BoundingBoxCamera.
◆ ConnectNewBoundingBoxes()
template<class T >
gz::common::ConnectionPtr ConnectNewBoundingBoxes ( std::function< void(const std::vector< BoundingBox > &)>  _subscriber)
overridepure virtual
Implemented in Ogre2BoundingBoxCamera.
◆ DrawBoundingBox()
template<class T >
void DrawBoundingBox ( unsigned char *  _data,
const math::Color &  _color,
const BoundingBox &  _box
) const
[in]_databuffer containing the image data
[in]_colorColor of the bounding box to be drawn
[in]_boxbounding box to be drawn
◆ SetBoundingBoxType()
template<class T >
void SetBoundingBoxType ( BoundingBoxType  _type)
[in]_typeBoundingBox Type (Visible / Full)
◆ Type()
template<class T >
BoundingBoxType Type ( ) const
◆ boundingBoxes
template<class T >
std::vector<BoundingBox> boundingBoxes
◆ type
template<class T >
