Ogre 1.x implementation of a Projector class. More...
#include <OgreProjector.hh>
virtual ~OgreProjector ()
 Set whether the projector is enabled or disabled.
- Public Member Functions inherited from BaseProjector< OgreVisual >
virtual ~BaseProjector ()
 Get the projector's far clipping plane distance.
 Get the projector's horizontal field-of-view.
bool IsEnabled () const override
 Get whether the projector is enabled or disabled.
 Get the projector's near clipping plane distance.
virtual void SetFarClipPlane (double _far) override
 Set the projector's far clipping plane distance.
 Set the projector's horizontal field-of-view.
virtual void SetNearClipPlane (double _near) override
 Set the projector's near clipping plane distance.
void SetTexture (const std::string &_texture) override
 Load a texture into the projector.
 Get the URI of the texture file used by the projector.
- Public Member Functions inherited from Projector
virtual ~Projector ()
virtual ~OgreVisual ()
 Set visibility flags.
 Enable or disable wireframe.
virtual ~BaseVisual ()
 Add visibility flags.
 Get the local pose.
 Remove visibility flags.
 Set the local pose.
 Get visibility flags.
virtual ~OgreNode ()
 Get the local scale.
 Get the parent Node.
 Get number of child nodes.
 Get the initial local pose.
 Get the local position.
 Get the local rotation.
 Get position of origin.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 OgreProjector ()
- Protected Member Functions inherited from BaseProjector< OgreVisual >
 BaseProjector ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseProjector< OgreVisual >
bool enabled
 Indicates whether or not the projector is enabled.
double farClip
 Projector's far clip plane.
math::Angle hfov
 Projector's horizontal field of view.
double nearClip
 Projector's near clip plane.
std::string textureName
 Texture used by the projector.
uint32_t visibilityFlags
 Visual's visibility flags.
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreProjector()
OgreProjector ( )
◆ ~OgreProjector()
virtual ~OgreProjector ( )
◆ SetEnabled()
[in]_enabledTrue to enable the projector.
Reimplemented from BaseProjector< OgreVisual >.
