A base implementation of the Projector class. More...
#include <BaseProjector.hh>
virtual ~BaseProjector ()
 Get the projector's far clipping plane distance.
 Get the projector's horizontal field-of-view.
bool IsEnabled () const override
 Get whether the projector is enabled or disabled.
 Get the projector's near clipping plane distance.
void SetEnabled (bool _enabled) override
 Set whether the projector is enabled or disabled.
virtual void SetFarClipPlane (double _far) override
 Set the projector's far clipping plane distance.
 Set the projector's horizontal field-of-view.
virtual void SetNearClipPlane (double _near) override
 Set the projector's near clipping plane distance.
void SetTexture (const std::string &_texture) override
 Load a texture into the projector.
 Get the URI of the texture file used by the projector.
- Public Member Functions inherited from Projector
virtual ~Projector ()
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
 BaseProjector ()
bool enabled = false
 Indicates whether or not the projector is enabled.
double farClip = 10.0
 Projector's far clip plane.
math::Angle hfov = math::Angle(0.785398)
 Projector's horizontal field of view.
double nearClip = 0.1
 Projector's near clip plane.
std::string textureName
 Texture used by the projector.
template<class T>
class gz::rendering::BaseProjector< T >
◆ BaseProjector()
template<class T >
BaseProjector ( )
◆ ~BaseProjector()
template<class T >
~BaseProjector ( )
◆ FarClipPlane()
template<class T >
double FarClipPlane ( ) const
Far clipping plane distance
Implements Projector.
◆ HFOV()
template<class T >
math::Angle HFOV ( ) const
Angle containing the projector's horizontal field-of-view
◆ IsEnabled()
template<class T >
bool IsEnabled ( ) const
true if enabled, false otherwise
◆ NearClipPlane()
template<class T >
Near clipping plane distance
◆ SetEnabled()
template<class T >
void SetEnabled ( bool  _enabled)
[in]_enabledTrue to enable the projector.
Reimplemented in OgreProjector, and Ogre2Projector.
◆ SetFarClipPlane()
template<class T >
void SetFarClipPlane ( double  _far)
◆ SetHFOV()
template<class T >
void SetHFOV ( const math::Angle &  _hfov)
◆ SetNearClipPlane()
template<class T >
void SetNearClipPlane ( double  _near)
◆ SetTexture()
template<class T >
void SetTexture ( const std::string &  _texture)
[in]_textureName of the texture to project.
◆ Texture()
template<class T >
std::string Texture ( ) const
◆ enabled
template<class T >
◆ farClip
template<class T >
◆ hfov
template<class T >
◆ nearClip
template<class T >
◆ textureName
template<class T >
