Projector Class Referenceabstract
A projector that projects a texture onto a surface. More...
#include <Projector.hh>
virtual ~Projector ()
 Get the projector's far clipping plane distance.
 Get the projector's horizontal field-of-view.
 Get whether the projector is enabled or disabled.
 Get the projector's near clipping plane distance.
 Set whether the projector is enabled or disabled.
virtual void SetFarClipPlane (double _far)=0
 Set the projector's far clipping plane distance.
 Set the projector's horizontal field-of-view.
virtual void SetNearClipPlane (double _near)=0
 Set the projector's near clipping plane distance.
virtual void SetTexture (const std::string &_texture)=0
 Load a texture into the projector.
virtual std::string Texture () const =0
 Get the URI of the texture file used by the projector.
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
gz/rendering/Projector.hh
◆ ~Projector()
virtual ~Projector ( )
◆ FarClipPlane()
virtual double FarClipPlane ( ) const
Far clipping plane distance
Implemented in BaseProjector< T >, BaseProjector< Ogre2Visual >, and BaseProjector< OgreVisual >.
◆ HFOV()
virtual math::Angle HFOV ( ) const
Angle containing the projector's horizontal field-of-view
◆ IsEnabled()
true if enabled, false otherwise
◆ NearClipPlane()
virtual double NearClipPlane ( ) const
Near clipping plane distance
◆ SetEnabled()
[in]_enabledTrue to enable the projector.
Implemented in BaseProjector< T >, BaseProjector< Ogre2Visual >, BaseProjector< OgreVisual >, OgreProjector, and Ogre2Projector.
◆ SetFarClipPlane()
virtual void SetFarClipPlane ( double  _far)
◆ SetHFOV()
◆ SetNearClipPlane()
virtual void SetNearClipPlane ( double  _near)
◆ SetTexture()
virtual void SetTexture ( const std::string &  _texture)
[in]_textureName of the texture to project.
◆ Texture()
