JointVisual Class Referenceabstract
Represents a joint visual. More...
#include <JointVisual.hh>
virtual ~JointVisual ()
virtual ArrowVisualPtr ArrowVisual () const =0
 Get the arrow visual which represents the axis attached to the child.
virtual gz::math::Vector3d Axis () const =0
 Get axis vector.
virtual gz::math::Vector3d ParentAxis () const =0
 Get parent axis vector.
virtual JointVisualPtr ParentAxisVisual () const =0
 Get the JointVisual which is attached to the parent.
virtual void SetAxis (const gz::math::Vector3d &_axis, bool _useParentFrame=false)=0
 Create an axis and attach it to the joint visual.
virtual void SetParentAxis (const gz::math::Vector3d &_axis, const std::string &_parentName, bool _useParentFrame=false)=0
 Create a parent axis for hinge2 and universal joint types and attach it to the joint visual.
virtual void SetType (const JointVisualType _type)=0
 Set type for joint visual.
virtual JointVisualType Type () const =0
 Get joint visual type.
virtual bool UpdateAxis (const gz::math::Vector3d &_axis, bool _useParentFrame=false)=0
 Update an axis' arrow visual.
virtual bool UpdateParentAxis (const gz::math::Vector3d &_axis, bool _useParentFrame=false)=0
 Update the parent axis' arrow visual if it exists.
 Add visibility flags.
 Remove visibility flags.
 Set visibility flags.
 Enable or disable wireframe.
 Get visibility flags.
 Get number of child nodes.
 Get the initial local pose.
 Get the local pose.
 Get the local position.
 Get the local rotation.
 Get the local scale.
 Get position of origin.
 Get the parent Node.
 Set the local pose.
 Set the local position.
 Set the local rotation.
 Set the local scale.
 Set the world pose.
 Set the world position.
 Set the world rotation.
 Set the world scale.
 Get the world pose.
 Get the world position.
 Get the world rotation.
 Get the world scale.
gz/rendering/JointVisual.hh
◆ ~JointVisual()
virtual ~JointVisual ( )
◆ ArrowVisual()
virtual ArrowVisualPtr ArrowVisual ( ) const
Arrow visual.
Implemented in BaseJointVisual< T >, BaseJointVisual< Ogre2Visual >, and BaseJointVisual< OgreVisual >.
◆ Axis()
virtual gz::math::Vector3d Axis ( ) const
Get axis vector.
The axis vector.
◆ ParentAxis()
virtual gz::math::Vector3d ParentAxis ( ) const
The parent axis vector.
◆ ParentAxisVisual()
virtual JointVisualPtr ParentAxisVisual ( ) const
Parent axis visual.
◆ SetAxis()
virtual void SetAxis ( const gz::math::Vector3d &  _axis,
bool  _useParentFrame = false
[in]_axisAxis vector.
[in]_useParentFrameTrue if axis vector is expressed in parent frame.
◆ SetParentAxis()
virtual void SetParentAxis ( const gz::math::Vector3d &  _axis,
const std::string &  _parentName,
[in]_parentNameJoint parent name.
◆ SetType()
virtual void SetType ( const JointVisualType  _type)
[in]_typeThe type of visualisation for joint.
◆ Type()
virtual JointVisualType Type ( ) const
The joint visual type.
◆ UpdateAxis()
virtual bool UpdateAxis ( const gz::math::Vector3d &  _axis,
True if axis was updated else false.
◆ UpdateParentAxis()
virtual bool UpdateParentAxis ( const gz::math::Vector3d &  _axis,
True if parent axis was updated else false.
