BaseStoreWrapper< T, U > Class Template Reference
#include <BaseStorage.hh>
 BaseStoreWrapper (UStorePtr _store)
virtual ~BaseStoreWrapper ()
 Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done.
 Remove and destroy given element. If the given element does not exists, in this store, then no work will be done.
virtual void DestroyAll ()
 Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual void RemoveAll ()
 Remove element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove element with the given name. If the specified element does not exists in this store, then no work will be done.
- Public Member Functions inherited from StoreWrapper< T, U >
virtual ~StoreWrapper ()=default
virtual ~Store ()=default
UStorePtr store
◆ BaseStoreWrapper()
template<class T , class U >
BaseStoreWrapper ( UStorePtr  _store)
◆ ~BaseStoreWrapper()
~BaseStoreWrapper ( )
◆ Add()
bool Add ( TPtr  _object)
True if successful
Implements Store< T >.
References std::dynamic_pointer_cast().
◆ Contains()
◆ ContainsId()
◆ ContainsName()
void Destroy ( TPtr  _object)
◆ DestroyAll()
void DestroyAll ( )
◆ DestroyById()
◆ DestroyByIndex()
◆ DestroyByName()
◆ GetById()
BaseStoreWrapper< T, U >::TPtr GetById ( unsigned int  _id) const
The specified element
◆ GetByIndex()
BaseStoreWrapper< T, U >::TPtr GetByIndex ( unsigned int  _index) const
◆ GetByName()
BaseStoreWrapper< T, U >::TPtr GetByName ( const std::string &  _name) const
◆ Remove()
BaseStoreWrapper< T, U >::TPtr Remove ( TPtr  _object)
The removed element
◆ RemoveAll()
void RemoveAll ( )
◆ RemoveById()
BaseStoreWrapper< T, U >::TPtr RemoveById ( unsigned int  _id)
The removed element
◆ RemoveByIndex()
BaseStoreWrapper< T, U >::TPtr RemoveByIndex ( unsigned int  _index)
The removed element
◆ RemoveByName()
BaseStoreWrapper< T, U >::TPtr RemoveByName ( const std::string &  _name)
The removed element
◆ Size()
unsigned int Size ( ) const
◆ store
UStorePtr store
