BaseSensorStore< T > Class Template Reference
#include <BaseStorage.hh>
- Public Member Functions inherited from BaseStore< Sensor, T >
 BaseStore ()
virtual ~BaseStore ()
 Add given element. If the element has already been added or its name or ID conflict with other existing elements, then no work will be done.
virtual UIter Begin ()
 Return an iterator to the beginning.
 Remove and destroy given element. If the given element does not exists, in this store, then no work will be done.
virtual void DestroyAll ()
 Remove and destroy element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove and destroy element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual UIter End ()
 Return an iterator to the end.
virtual void RemoveAll ()
 Remove element with the given ID. If the specified element does not exists in this store, then no work will be done.
 Remove element at the given index. If the specified element does not exists in this store, then no work will be done.
 Remove element with the given name. If the specified element does not exists in this store, then no work will be done.
virtual ~Store ()=default
- Protected Member Functions inherited from BaseStore< Sensor, T >
 Get a const iterator to the object by pointer. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get a const iterator to the object by id. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get a const iterator to the object by index. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get a const iterator to the object by name. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get an iterator to the object by pointer. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get an iterator to the object by id. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get an iterator to the object by index. Note that the iterator may change or become invalid when objects are added to / removed from the store.
 Get an iterator to the object by name. Note that the iterator may change or become invalid when objects are added to / removed from the store.
- Protected Attributes inherited from BaseStore< Sensor, T >
UStore store
UStoreMap storeMap
