gz/rendering/Node.hh
virtual bool HasParent() const =0
virtual bool HasChildId(unsigned int _id) const =0
virtual void AddChild(NodePtr _child)=0
Definition: gz/rendering/Node.hh:37
STL class.
virtual void SetLocalPosition(double _x, double _y, double _z)=0
Set the local position.
virtual math::Vector3d WorldPosition() const =0
Get the world position.
virtual NodePtr RemoveChildById(unsigned int _id)=0
Remove (detach) the node with the given ID from this node. If the specified node is not a child of th...
virtual NodePtr ChildByIndex(unsigned int _index) const =0
virtual NodePtr ChildByName(const std::string &_name) const =0
virtual math::Vector3d LocalPosition() const =0
Get the local position.
virtual void SetLocalScale(double _scale)=0
virtual void RemoveParent()=0
virtual NodePtr RemoveChild(NodePtr _child)=0
Remove (detach) the given node from this node. If the given node is not a child of this node,...
virtual void RemoveChildren()=0
virtual NodePtr ChildById(unsigned int _id) const =0
virtual void SetWorldPose(const math::Pose3d &_pose)=0
Set the world pose.
virtual unsigned int ChildCount() const =0
Get number of child nodes.
virtual math::Vector3d WorldScale() const =0
Get the world scale.
virtual bool InheritScale() const =0
Determine if this visual inherits scale from this parent.
virtual void SetLocalRotation(double _r, double _p, double _y)=0
Set the local rotation.
virtual void SetLocalPose(const math::Pose3d &_pose)=0
Set the local pose.
virtual void SetWorldRotation(double _r, double _p, double _y)=0
Set the world rotation.
virtual void SetWorldScale(double _scale)=0
virtual math::Vector3d LocalScale() const =0
Get the local scale.
virtual bool HasChild(ConstNodePtr _child) const =0
virtual math::Pose3d WorldToLocal(const math::Pose3d &_pose) const =0
virtual void SetWorldPosition(double _x, double _y, double _z)=0
Set the world position.
virtual bool HasChildName(const std::string &_name) const =0
virtual math::Quaterniond LocalRotation() const =0
Get the local rotation.
virtual math::Quaterniond WorldRotation() const =0
Get the world rotation.
virtual NodePtr RemoveChildByIndex(unsigned int _index)=0
Remove (detach) the node at the given index from this node. If the specified node is not a child of t...
Definition: gz/rendering/Object.hh:34
virtual void SetOrigin(double _x, double _y, double _z)=0
virtual NodePtr RemoveChildByName(const std::string &_name)=0
Remove (detach) the node with the given name from this node. If the specified node is not a child of ...
virtual void Scale(double _scale)=0
Scale the current scale by the given scalar. The given scalar will be assigned to the x,...
virtual void SetInheritScale(bool _inherit)=0
Specify if this visual inherits scale from its parent.
