gz/rendering/RenderTypes.hh File Reference
#include <memory>#include <gz/rendering/config.hh>Go to the source code of this file.
Namespaces | |
| ignition | |
| ignition::rendering | |
| Rendering classes and function useful in robot applications. | |
Macros | |
| #define | IGN_VISIBILITY_ALL 0x0FFFFFFF |
| Render everything visibility mask. More... | |
| #define | IGN_VISIBILITY_GUI 0x00000001 |
| Render GUI visuals mask. More... | |
| #define | IGN_VISIBILITY_SELECTABLE 0x00000002 |
| Render visuals that are selectable mask. More... | |
| #define | IGN_VISIBILITY_SELECTION 0x10000000 |
| Renders only objects that can be selected. More... | |
Typedefs | |
| typedef shared_ptr< ArrowVisual > | ArrowVisualPtr |
| Shared pointer to ArrowVisual. More... | |
| typedef shared_ptr< AxisVisual > | AxisVisualPtr |
| Shared pointer to AxisVisual. More... | |
| typedef shared_ptr< Camera > | CameraPtr |
| Shared pointer to Camera. More... | |
| typedef shared_ptr< const ArrowVisual > | ConstArrowVisualPtr |
| typedef shared_ptr< const AxisVisual > | ConstAxisVisualPtr |
| typedef shared_ptr< const Camera > | ConstCameraPtr |
| typedef shared_ptr< const DepthCamera > | ConstDepthCameraPtr |
| typedef shared_ptr< const DirectionalLight > | ConstDirectionalLightPtr |
| typedef shared_ptr< const GaussianNoisePass > | ConstGaussianNoisePass |
| Shared pointer to const GaussianNoisePass. More... | |
| typedef shared_ptr< const Geometry > | ConstGeometryPtr |
| typedef shared_ptr< const GizmoVisual > | ConstGizmoVisualPtr |
| typedef shared_ptr< const GpuRays > | ConstGpuRaysPtr |
| typedef shared_ptr< const Image > | ConstImagePtr |
| typedef shared_ptr< const JointVisual > | ConstJointVisualPtr |
| typedef shared_ptr< const Light > | ConstLightPtr |
| typedef shared_ptr< const Material > | ConstMaterialPtr |
| typedef shared_ptr< const Mesh > | ConstMeshPtr |
| typedef shared_ptr< const Node > | ConstNodePtr |
| typedef shared_ptr< const ObjectFactory > | ConstObjectFactoryPtr |
| typedef shared_ptr< const Object > | ConstObjectPtr |
| typedef shared_ptr< const PointLight > | ConstPointLightPtr |
| typedef shared_ptr< const RayQuery > | ConstRayQueryPtr |
| typedef shared_ptr< const RenderPass > | ConstRenderPassPtr |
| typedef shared_ptr< const RenderPassSystem > | ConstRenderPassSystemPtr |
| typedef shared_ptr< const RenderTarget > | ConstRenderTargetPtr |
| typedef shared_ptr< const RenderTexture > | ConstRenderTexturePtr |
| typedef shared_ptr< const RenderWindow > | ConstRenderWindowPtr |
| typedef shared_ptr< const Scene > | ConstScenePtr |
| typedef shared_ptr< const Sensor > | ConstSensorPtr |
| typedef shared_ptr< const ShaderParams > | ConstShaderParamsPtr |
| Shared pointer to const ShaderParams. More... | |
| typedef shared_ptr< const SpotLight > | ConstSpotLightPtr |
| typedef shared_ptr< const SubMesh > | ConstSubMeshPtr |
| typedef shared_ptr< const Text > | ConstTextPtr |
| typedef shared_ptr< const ThermalCamera > | ConstThermalCameraPtr |
| typedef shared_ptr< const Visual > | ConstVisualPtr |
| typedef shared_ptr< DepthCamera > | DepthCameraPtr |
| Shared pointer to DepthCamera. More... | |
| typedef shared_ptr< DirectionalLight > | DirectionalLightPtr |
| Shared pointer to DirectionalLight. More... | |
| typedef shared_ptr< GaussianNoisePass > | GaussianNoisePassPtr |
| Shared pointer to GaussianNoisePass. More... | |
| typedef shared_ptr< Geometry > | GeometryPtr |
| Shared pointer to Geometry. More... | |
| typedef shared_ptr< GizmoVisual > | GizmoVisualPtr |
| Shared pointer to GizmoVisual. More... | |
| typedef shared_ptr< GpuRays > | GpuRaysPtr |
| Shared pointer to GpuRays. More... | |
| typedef shared_ptr< Grid > | GridPtr |
| Shared pointer to Grid. More... | |
| typedef shared_ptr< Image > | ImagePtr |
| Shared pointer to Image. More... | |
| typedef shared_ptr< JointVisual > | JointVisualPtr |
| Shared pointer to JointVisual. More... | |
| typedef shared_ptr< Light > | LightPtr |
| Shared pointer to Light. More... | |
| typedef shared_ptr< Marker > | MarkerPtr |
| Shared pointer to Marker. More... | |
| typedef shared_ptr< Material > | MaterialPtr |
| Shared pointer to Material. More... | |
| typedef shared_ptr< Mesh > | MeshPtr |
| Shared pointer to Mesh. More... | |
| typedef shared_ptr< Node > | NodePtr |
| Shared pointer to Node. More... | |
| typedef shared_ptr< ObjectFactory > | ObjectFactoryPtr |
| Shared pointer to ObjectFactory. More... | |
| typedef shared_ptr< Object > | ObjectPtr |
| Shared pointer to Object. More... | |
| typedef shared_ptr< PointLight > | PointLightPtr |
| Shared pointer to PointLight. More... | |
| typedef shared_ptr< RayQuery > | RayQueryPtr |
| Shared pointer to RayQuery. More... | |
| typedef shared_ptr< RenderPass > | RenderPassPtr |
| Shared pointer to RenderPass. More... | |
| typedef shared_ptr< RenderPassSystem > | RenderPassSystemPtr |
| Shared pointer to RenderPassSystem. More... | |
| typedef shared_ptr< RenderTarget > | RenderTargetPtr |
| Shared pointer to RenderTarget. More... | |
| typedef shared_ptr< RenderTexture > | RenderTexturePtr |
| Shared pointer to RenderTexture. More... | |
| typedef shared_ptr< RenderWindow > | RenderWindowPtr |
| Shared pointer to RenderWindow. More... | |
| typedef shared_ptr< Scene > | ScenePtr |
| Shared pointer to Scene. More... | |
| typedef shared_ptr< Sensor > | SensorPtr |
| Shared pointer to Sensor. More... | |
| typedef shared_ptr< ShaderParams > | ShaderParamsPtr |
| Shared pointer to ShaderParams. More... | |
| template<class T > | |
| using | shared_ptr = std::shared_ptr< T > |
| typedef shared_ptr< SpotLight > | SpotLightPtr |
| Shared pointer to SpotLight. More... | |
| typedef shared_ptr< SubMesh > | SubMeshPtr |
| Shared pointer to SubMesh. More... | |
| typedef shared_ptr< Text > | TextPtr |
| Shared pointer to Text. More... | |
| typedef shared_ptr< ThermalCamera > | ThermalCameraPtr |
| Shared pointer to ThermalCamera. More... | |
| typedef shared_ptr< Visual > | VisualPtr |
| Shared pointer to Visual. More... | |
Macro Definition Documentation
◆ IGN_VISIBILITY_ALL
◆ IGN_VISIBILITY_GUI
◆ IGN_VISIBILITY_SELECTABLE
◆ IGN_VISIBILITY_SELECTION
