Visual Class Referenceabstract
Represents a visual node in a scene graph. A Visual is the only node that can have Geometry and other Visual children. More...
#include <ignition/rendering/Visual.hh>
virtual MaterialPtr Material ()=0
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
◆ ~Visual()
virtual ~Visual ( )
inlinevirtual
Deconstructor.
◆ AddGeometry()
virtual void AddGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be added
Implemented in BaseVisual< T >, BaseVisual< Ogre2Node >, and BaseVisual< OgreNode >.
◆ GeometryByIndex()
virtual GeometryPtr GeometryByIndex ( unsigned int  _index) const
[in]_indexIndex of the desired geometry
The specified geometry
◆ GeometryCount()
virtual unsigned int GeometryCount ( ) const
The number of geometries attached to this visual
Implemented in BaseVisual< T >.
◆ HasGeometry()
virtual bool HasGeometry ( ConstGeometryPtr  _geometry) const
[in]_geometryGeometry in question
True if given node is attached to this visual
virtual MaterialPtr Material ( )
◆ RemoveGeometries()
virtual void RemoveGeometries ( )
◆ RemoveGeometry()
virtual GeometryPtr RemoveGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be removed
The removed geometry
◆ RemoveGeometryByIndex()
virtual GeometryPtr RemoveGeometryByIndex ( unsigned int  _index)
[in]_indexIndex of the geometry to be removed
◆ SetChildMaterial()
virtual void SetChildMaterial ( MaterialPtr  _material,
bool  _unique = true
◆ SetGeometryMaterial()
virtual void SetGeometryMaterial ( MaterialPtr  _material,
bool  _unique = true
◆ SetMaterial() [1/2]
bool  _unique = true
[in]_nameName of the material to be assigned
◆ SetMaterial() [2/2]
bool  _unique = true
◆ SetUserData()
virtual void SetUserData ( const std::string &  _key,
Variant  _value
[in]_keyUnique key
[in]_valueValue in any type
◆ SetVisible()
Implemented in BaseVisual< T >, BaseVisual< Ogre2Node >, BaseVisual< OgreNode >, Ogre2Visual, and OgreVisual.
◆ UserData()
virtual Variant UserData ( const std::string &  _key) const
[in]_keyUnique key
Data associated with the key.
